- WA2ZKD
- 16,165
- 14
Mark.... your giving up the overhead stuff by that "sideways" aim. Put an old tin pie plate on a sidearm, as long as the antenna coax permits, and face it up.
https://www.dropbox.com/s/pbba91mitc79p2d/Z5100A%20Manual%2001.pdf?dl=0
The eastern variants of those shore stations are scarce, if any (?). My KiwiSDR in Maine provides good omni coverage in the NE http://rx2.wa2zkd.net:8073/
I have had a old Pi as a Stratum 1 ntp server for years. I used an Adafruit module and all the computers in my house use it as the primary server.
the open/open case does not need a fan
I have done 6 of them and always just followed the instructions at the very start of this thread, and had no issues
This contains info on Europe and other end points https://www.raft-tech.com/raft-articles/
Within the HF industry, WBHF generally refers to that which is described here, http://tracebase.nmsu.edu/hf/MIL-STD-188-110D.pdf, or another scheme developed in France. HFT, in which the words High Frequency refers to stock trading rather than rad…
how do the AGC timing values that a standalone kiwi uses compare to those of kiwiclient Found it var default_agc = 1; var default_hang = 0; var default_manGain = 50; var default_thresh = -130; var default_slope = 6; var default_decay = 1000;
I am aware of testing of eLORAN stuff in CONUS
try... antenna+ferrite-----------------------ferrite+(coax junction with good ground)+ferrite-------------------------Ferrite+radio
with both of the answer above, I have what I need... Thanks to both of you.
John... anyone.. ?
You might also try the Linux program jq which you can run on the BB, it is already on it
http://forum.kiwisdr.com/discussion/comment/7683#Comment_7683
I am not but some time ago. I used JSON -> text tools to produce flat files then text -> JSON. I hve a dropbiox repository. There is more info in an old post here
do you have both 3.7 and 3.8 available on the same machine now?
I struggled with that and put project on hold... you are not alone!
In wsprdaemon... You could do a simple mod to excecute a script on schedule. It already knows about sunrise/sunset so you could doing something based on time . Or, you could mod it to run a script on every cycle and check for sunshine and act.
reduce the antenna less and see what happens
what kind of antenna?
I have successfully used Christoph's combined stream technique but it's not something for newbies to try!
at the same time, eLORAN is being explored rather than have GPS be a SPoF.... !
someone persistantly listening on that freq is more than a fan IMO
this seems analog (?) (Image)
I have an Odroid XU4 running Ubuntu and wsprdaemon.... connected 2 each KiwiSDR/BBAI... 28 channels at once. Runs just fine.
The status of OpenwebRX has no impact on the KiwiSDR
I think you want to convert dBm to milliwatts before your calculation
dBm is an absolute quanity, referenced to 1 milliwatt. I think what you want is dB which are relative. You can adjust to any level of relative dB you want.
The better HF squelches use a syllabic technique but even that can fall victim to QSB. With the advent of Digital Voice, less non-hobby HF users need squelch as that is taken care of with the Vocoder.
