- WA2ZKD
- 16,165
- 14
2G uses an asyncronous channel scan scheme.... just to add to the design agony here.
seems ready for prime time
Still running solid and at the same time, I'm learning a bit about my antenna systems and local NVIS condx.
nothing in the json file buffer either
Have TX sounding every 5 minutes all morning and been decoding with BER as high as 20 (poor) or as low as 2 (VG) with no issues
Morning report..... at 1010Z when the band opened on this NVIS path, it decoded a barely discernable Sound just fine http://forum.kiwisdr.com/uploads/720/UQCSZ202DICX.png
ALE TX via PRC-150C
that will run periodlly LQA sounds I'll check as night goes on
4416.9 kHz dial freq is my test freq
that would be fine its a BBAI box so a bit faster
No I have an actual ALE station with a 150W radio 100 miles form my kiwi (near Utica NY) It'll be a little bit before that is up and running ... want to lock it to a single freq and just run Sounds Source s Mil-compliant hardware based ALE system M…
when do you want to test? I can do it now obviously I need extension on my box
I can provide test signals to my kiwi if that will help
rework to follow here... 4 times! I am going to do it with eBay item 173898127317
yes, you have the concept correct Tnx
Update: 4G spec has been out for awhile, and implementations exist. 3G continues to supplant 2G although I suspect 2G will be around for awhile.
very nice!
does the SAM Carrier Offset still apply to C-QUAM? It is displayed
great
OK... will it include 120 ?
