- WA2ZKD
- 16,165
- 14
http://jimlill.com:8073 would have the same issue without notches.... http://forum.kiwisdr.com/uploads/536/EATURVPGK119.png
I "enjoy" the same situation here and needed notches on the worst MWBC stations.
Rather than restarting the server, maybe John can advise on how to perform the "autorun restart" command from the an OS shell
If I was sure of the right OS level command to restart the server I'd help you more on this. Perhaps John (jks) will weigh in.
the frequency is contained within the kiwi.json file. An adventuresome approach might be to cron a script that swaps that file and then restart the server
I don't believe so...
The Music/MIDI people do a lot of related stuff, it might be worth a look into that world.
IMO, the SNR values can be misleading. I have noted systems with great numbers that have limited usefulness due to be ridden with a lot of discrete spurs.
do you keep that as the active window or move from it to look at another browser window? -Jim
Thank you!
The reason a wrote that is I have mulitple Kiwi which miostly the same set of labels applies to. Over the years, their DX labels got out of sync. With this tool, I can make a superset of all of them and then delate the ose that doesn't apply. That i…
what is Field 6?
Is there a list of the guys with unrecorded? I'd be happy to try to track down what they run.
un-recorded might also include Red Pitaya spots which is what I think EA8BFK uses
Here's what an entry in dx.json if beautified... [ 37.5, "CWN", "NRK", "Grindavik Iceland", 279996, 7793 ], Is there a place in the kiwi src code that defines each line?
I have a script I wrote awhile ago that merges 2 dx.json files. I'll clean it up and make it available.
wsprnet seems to filter if transmitter call = reporter call FWICT from my 630M work
sudo bash works well too
as for changing IP#. I always lock the IP# I want to the MAC in my router and let the kiwi dhcp it.
there is no root PW until you set it I thought (?)
is a DN propagation time issue? whois doesn't find on5kq.ddns.net
are you able to ssh ans sudo to root? If so, this may do it cd [goes to /root]After rebooting from the update login again and from a root shell do: cd [goes to /root] git clone https://github.com/jks-prv/Beagle_SDR_GPS.git cd Beagle_SDR_GPS make cl…
IIRC going into SAM invokes a different demodulation path
there or may not be an issue..... I may have looked too early today (pre coffee)
https://www.mouser.com/pdfdocs/Seeed-BBG_SRM_V3_20150804.pdf
There is a 1440 Hz preamble that is visible at the start of each transmission. With very weak signals, somethimes I only see the preamble faintly. Just an observation. https://cartoonman.github.io/WAVECOM/wavecomhtm/hfacars.htm
unplug the kiwi cape and see what the BBG alone does
when extension is open not all of the right-click menu is visible
if your voltage sags below a threshold, which I forget what it is, things can go awry. http://forum.kiwisdr.com/index.php?p=/discussion/comment/11784#Comment_11784
can you tweak your acopian up to 5.05?
