 - WA2ZKD
 - 16,165
 - 14
                at the OS level, where do I find the kiwi logs
                on a related note.... the "troll cycle" always lasts 1:32
                These guys seem to be a prime source of the recurrent kiwirecorder.py connects. https://www.choopa.com/datacenter/
                I have 4, sometimes 5 at my location running. I brought some order to things by assigning the LAN IP and port as such: 192.168.1.73:8073 ..... 192.168.1.75:8075 etc.
                https://www.python.org/ftp/python/3.10.4/python-3.10.4-amd64.exe here's what you need for W10
                Just install python on your Windows box and you should be on your way. That install is pretty much plug and play after installing python get into a command line prompt and use the command pip install numpy I just did that fresh on a W10 box and it …
                I put it back to 9.9 and all built and works fine. Not sure what @rz3dvp did to get 10 going
                @rz3dvp. perhaps you could post some script snips to show how yo udo this
                My misery may be self-imposed. I upgraded to Buster to get the rest of Linux current for that non-kiwi stuff I am going to trying to run on the same BBAI dog output: Debian 10.11 BeagleBoard.org Debian Buster IoT TIDL Image 2020-04-06 Linux beagleb…
                John.... I'll back up a rev. if needed!
                I am trying to build a system on a new BBAI with buster installed. when I run the make I see Makefile:1016: warning: overriding recipe for target 'install_kiwi_device_tree' Makefile:1000: warning: ignoring old recipe for target 'install_kiwi_device_…
                if you go right into the admin status page, does it freeze up there?
                which OS and browser are you using?
                my waveform professional buddies advise that the SDR-Console SNR method is pretty sound. See comment from Benson above. https://www.sdr-radio.com/s-meter
                Yes, I was hoping people might post some code snippets
                perhaps someone needs to subscribe, then access their own kiwi and see what IP# appears on it
                sort of sleazy IMO
                SDR-Console App has an SNR meter option.
                I know that..... had not heard of bots in Singapore before. They run a tight ship there so surprised
                a single Sinagpore connection? There are legit users there.
                now I can't remember what I called it in the subject of my original post! :-) Thanks for the clarification.
                this was the area I was referring to... https://forum.kiwisdr.com/uploads/266/I9CY5CPT7PI2.png
                Thank you for the clarification
                New unit? then it's updating its firmware and that may take an hour.
                Syllabic squelch = VAD WebRTC seems to have some promise https://github.com/wiseman/py-webrtcvad
                I have contacted a few US OPs directly offering to help. They were having troubles, helped them through it and we're now down to < 5%
                can that filter be applied to the output of kiwiclient/recorder sessions?
                order radios might be using 2G ALE and 39T modem for data and/or digital voice
                The 8-ary tones that ALE uses are somewhat unique to ALE. After the linking there is no restriction on what info is sent.
                yes, it is 2G ALE
