- WA2ZKD
- 16,165
- 14
as my only OV threats sre several MWBC stations, I use a few simple notch filters for those stations before the LNA. https://forum.kiwisdr.com/index.php?p=/discussion/593/am-overload-solved#latest
Linear versus switch-mode is an ongoing quest and debate. I have tried both over the years on the Kiwi and other SDR I have found these to be quiet and with a DIN rail, easily mounted Other users have used Meanwell in other chassis types. https://ww…
sox will also resample wav files
pretty common in dry / dusty climates. Here in NE USA it can occur on a dry cold snowy day. A simple 1Mohm bleeder on any antenna without a DC path is enough.
I note a line across the top of your screenshot... "most up to date" etc Is that something you recently added in your kiwi config?
seem OK here
103.135.104.143 124.205.145.240 a new pain here
you might consider using wsprdaemon as it will do complex scheduling and band changing
Contrary to what many might believe, the GPS footprint is not uniform the world over. There is a scalloped footprint at each of the polls. Here in upstate NY, I can't even consider a northern only coverage antenna location as I sit in one of the nul…
does your GPS puck have an omni view of the sky and if not, which direction does it favor.
https://www.w0qe.com/Projects/rf_clipper_2016.html
somone used my WA2ZKD call.... so that might mislead an admin thinking "oh it's Jim"..... nothing is safe
https://www.hasco-inc.com/tools/sma-3-5mm-2-92mm-2-4mm-1-85mm-connector-finger-thumb-wrench-blue/?gad_source=1&gclid=Cj0KCQjwlN6wBhCcARIsAKZvD5hXAJx8WCF3kf3eDiBYdL87IIY0besx3Tmluc7X5sO9LBwju3CeJjIaAp_lEALw_wcB
people are using other's callsigns to ID themselves on login.
try the Meanwell MDR-60-5
if you're just measuring loss, that with be in dB and regardless of dBm from source, dB is the same relative loss.
Shouldn't really need to know level of VNA... normalize the P1 to P2 to 0dB as you normally would P1 to Ant1, P2 to Ant2 read dB loss apply that loss to your TX power to find reduced level at other antenna
find and use a 3-4A PSU...
1 amp is inadequate and a 2A PSU may slump...
75 Ohm good for all HF RX
Thank You!
will try, thanks
the 2 14ch (wspr) systems got hosed during the 1.660 thing and I had to build them from an image. They both are Debian 9.12 BeagleBoard.org Debian Stretch IoT Image 2020-06-01 Linux kiwisdr 4.14.108-ti-r135 #1stretch SMP PREEMPT Fri May 15 18:38:28 …
My 4 AI have plenty of cooling, even 12+ ch of wspr they run 32C and I see they want to run at 400 MHz recently. Update: it only happens on my 2 14ch ones, my 3 and 4 ch are OK at 1000 MHz
that MMWS is a simple choke.... they can be done with clamp on ferrites thus no interruption in coax https://d2j6dbq0eux0bg.cloudfront.net/images/10325621/3193439254.jpg
a longwire + 9:1 balun would work too... could be all DIY or: https://winradio.com/home/lwa.htm
@SM6MUY regardless of antenna/kiwi, I note that you are in a location with the dip in your northern footprint. I wonder where your antenna is relative to things that might block your GPS antenna's southern view?
My data is only as good as the official sources provide and effects of the internet... but here's something I put together.. I'm more concerned about the proton event which can last days.. "http://www.jimlill.com:8088/muf/ezsun.html"
what cooling you'd need for a BBG you'll need for the AI
both OK on restart
