ShaneBrook
Can You Have a Check Box To Activate a Floating Window That Stays On Top Of The Current Window That Shows The Tuned Frequency In Selectable Font Size and Type for Sight Impaired People?
Thanks.
- ShaneBrook
- 533
- 1
how do you do that ..... change PW?
FT8 Fields went blank... I had put then in before... OK Now.
OH, I forgot... FT8 Autorun Dose not work also... It worked before upgrade to V 1.601 and that's when I couldn't get web page...
Using V 1.601, I can't use the password for ssh (Putty or Winscp). Even in admin tap set to 1234 dose not work... even after Kiwisdr server restart or Beagle reboot. What can I do to fix this?
I was holding down the wrong button, The Reset button.... The button for Boot is on the other end of power supply.... When I did it right everything worked fine... I am now up and running again.... Thanks for all of the help.....
I tried to install a new copy of kiwisdr from the webpage..... and it didn't power down like it said it would do when done..... so I cut the power off then powered on..... then same thing..... Using this command with SSH.... ps -A | grep "kiwid…
Yes, Nothing Listed....
I started to use FireFox (updated V 110.0.1), and Kiwisdr (just updated downloaded Last night to V 1.558) and looked at admin... and 3 have been connected for 13 Hrs and 20 Mins and 4 for 3 hrs and 38 mins doing FT8 and WSPR (IWBP) 18 hrs and 15 min…
I can't get wspr to work anymore... Maybe one of the last updates?
Just did update.... ran for 5 hrs. now... Still screen stopping on windows that are tabs that your weren't watching.... the tab that you could see all the time, that window was still working... The waterfall still moving... Looked at admin at status…
Wrong... It did do the same thing on the desktop as HP laptop.... Just took longer. Is it the computer or Kiwisdr or web browser...? What web browser is the best for Kiwisdr?
I just checked it out, On a desktop computer it works ok with opera web browser. Must be just on my laptop HP. computer.
OK, Thanks......
I know how to see the users that use my KiwiSDR receiver. How do I see The WSPR Results? Like the received WSPR stations and the Distance away, and concert to Miles so I can see Miles and Kilometers? Thank You......
It's just the TAB that deletes... Sorry, Yes I explanted it in a confusing way....
I see now..... Thanks....
is this ok? I did Kiwi address + Status
Ok........ Thanks, That was easy.....
Webpage Tab Now works..... Thanks
I did what you said..... It worked! ..... Fixed.... Web Page Tab Stuff won't update with my Info added...
Ok, What are the commands....
Here it is............... Aug 6 00:39:43 kiwisdr kiwid: 00:00:00.857 KiwiSDR v1.550 -------------------------------------------------------------------- Aug 6 00:39:43 kiwisdr kiwid: 00:00:00.860 compiled: Aug 5 2022 20:36:59 on kiwisdr Aug 6 00:…
PuTTY and WInSCP I use 192.168.xxx.77
This use to work.... kiwisdr.local:8073 Now it Doesn't I connect this way: 192.168.xxx.77:8073 192.168.xxx.77:8073/admin 192.168.xxx.77:8073/Status
Update finished... No errors.... Still can't get https screen... Putty and WinSCP works.... The Opera Web Browser was no screen... It did connect though..... Should I reinstall from old version... Then update?
Can I force an update? cdp then up ? The last update I saw was v 1.545, maybe something happened on one of the others? The last time I used the KiwiSDR Opera wouldn't work hade to use FireFox or Microsoft Edge. How do I know what OS Version do I hav…
Thanks for doing this.... It works great for me now.....
I am doing this for US CB Radio Band.... Like this: 26965 - 27405 MHz CB Radio USA Armature show on band menu only 10 27025am the channel spacing stays the same.... 5KHz... I even did server restart.... Thanks.....
Wish it had a Am Stereo Led light..... That would be cool....
JKS, Did you try that combination? That's when the ones that are fixed change frequency's....
