LX1DQ
- LX1DQ
- 594
- 1
"At one point last night it was decoding 630 WSPR spots per minute." Thanks for the experiment. You mean per 630 spots per hour I suppose or 10 per minute. 10 per second would be amazing.
It's 14 wspr channels in total you could listen to on a kiwi: LF MF 160 80a 80b 60a 60b 40 30 20 17 15 12 10
And asking a question changes the answer. It can be experimentally tested and found true within the experimental acuracy of the setup.
My Kiwi might have missed a few signals due to a busy CPU, but it was one of the few european WSPR receiving stations that heard your signal from Kaui tonight @rrobinet. Running 4 Kiwis 24/7 with 4 channels each in autoWSPR mode. Very stable and I a…
I wonder how they do that? Would have to be a lightweight VPN/proxy of some sort I guess. Anyone know? Ublock Origin is open source: https://github.com/gorhill/uBlock
With callsign set in upper right, I see the callsign in the lower left. Changes done in the callsign field also appear correctly. As for the location, with Firefox I have "unknown location" and with Chrome I have "Luxembourg". T…
Kudos and thank you.
One of my Kiwis running WSPR on 160, 80, 60 and 40m simultaneously has frozen 5 times after 1.79 update. Never froze before. The other Kiwi running WSPR on 30, 20, 17 and 15m is running with no problem 24/24h. Maybe this observation helps. Frank, …
I tried Firefox v53 (64bit) with Linux Mint 18.1 (Serena) Cinnamon and I noticed no CPU increase. Frank - LX1DQ
