KU4BY
- KU4BY
- 303
- 1
Well so far so good this morning after configuring static IP addresses. Those examples were from the point where The Orbi and both kiwisdrs had power restored at the same time so it's likely the issue was the Orbi took longer to come back online as…
Yeah changing my /etc/hosts file didn't fix it. Here's what I got from netc. This was from earlier today after a power failure so I'm thinking the Orbi was coming back online at the same time which probably caused the carrier losses. Since I'm alre…
OK, so I may or may not have figured out what was going on with it. My /etc/hosts file on both kiwisdrs had my kiwis pointing to 127.0.0.1. So I changed that to the actual LAN IP of the kiwisdr for each. I also changed the hostnames of both of them…
Both are running 1.815 on Linux 11. They were both running 1.815 on the old BBs as well. Since I posted this earlier today, I noticed that both of the receivers are doing it now. It may be sporadic. I don't have anything purposely running IPV6 but …
I had a nearby lightning strike take out both of my receivers (V1 and V2) and my cheap Harbor Freight solar charge controller last week. The receivers both shutdown right after the strike. Neither the BBB or the BBG would even light up when power w…
I got hit by them a couple times earlier this week and then it stopped. Yesterday I had a few pop in here and there but that was it. Today, I got slammed on both receivers. I let it ride for a while to see if I could figure out what they were up to…
@jks Thanks! I just received the shipping e-mail a couple of hours ago.
Well dang, I'm #1072....
Thanks, I didn't get a chance to test it again prior to my device updating but it is working fine now.
I pasted the IP address and positioned the cursor right behind it and hit enter like I have done numerous times before but the cursor just kept dropping down to the next line. The box didn't flash or anything. Perhaps the kiwi was glitching because …
At least 1 for me as well. Probably 2 though.😂
Cool, I never listen down that low. I am fairly close to the Atlantic and my noise floor is typically pretty low so I guess it makes sense. Thanks for checking it out.
Thanks, so now it sounds like China is trying to use my kiwi to spy on US Navy sub comms? During the day I have no reception from PR except around the CB band but I can hear a beacon from there at night on lw so maybe so. Perhaps I'll unblock them…
I got a couple hits from "directTD0A_v7.02" today. It was connecting every few minutes and parking on a single frequency. Anyone know if this is a legit use or have they just changed the way they do things? I kicked them a few times and th…
@ChrisSmolinski Yeah when we first started noticing this, they weren't showing up in the Admin page because of how they were accessing the receivers so there was no way of kicking or banning them from the GUI. You had to do it at the OS level and I'…
My kiwi has been pretty quiet but I had a couple more kiwirecorder hits this past week. One was an OP in China recording EAM messages in one hour segments every hour on the hour so effectively tying up a channel for a whole day before I caught it. I…
@o00scorpion00o Your situation sounds completely different with the exception of kiwirecorder.py being used. Kiwirecorder.py is a python script where you can automate to record data from the kiwisdr's. Anyone and everyone can use it and if they leav…
Sorry about that. I update the list under Admin every time it says a new list is available. I figured if they were scanning me then they weren't on it. I'll verify next time. Thanks!
And I just got hit by 2 more. May 7 13:06:44 kiwisdr kiwid: 22:08:24.453 01.3 2 292.97 kHz WF z8 "kiwirecorder.py" 216.238.81.138 Mexico City, Mexico (LEAVING after 0:01:13) May 7 13:06:58 kiwisdr kiwid: 22:08:38.647 01.. 3 4…
Thanks @jks . Here's another. May 6 15:16:54 kiwisdr kiwid: 00:18:34.490 012. 2 58.59 kHz WF z8 "kiwirecorder.py" 141.164.57.204 (ARRIVED) May 6 15:18:29 kiwisdr kiwid: 00:20:09.538 01.. 2 28125.00 kHz WF z3 "kiwirecord…
I had a couple more yesterday. Piscataway and Houston. May 5 14:22:11 kiwisdr kiwid: 1d:00:09:53.524 0... 1 28125.00 kHz WF z3 "kiwirecorder.py" 104.238.132.42 Piscataway, New Jersey, USA (LEAVING after 0:01:3 3) May May 5 15:34:2…
I got a new hit last night from the Netherlands. They were hitting me every 20 to 45 minutes or so for a bit. Just sharing. Apr 30 19:30:32 kiwisdr kiwid: 3d:16:05:34.548 0... 0 58.59 kHz WF z8 "kiwirecorder.py" 199.247.26.127 (AR…
The amount of time they stay connected has never been consistent on mine. It's always between 1:31 and 1:34. Here's an example from just a few days ago. All from the same IP address and you can see how the times fluctuate. https://forum.kiwisdr.com/…
Good morning @jks , I was backing up my sd card from the Admin page backup tab yesterday and about a minute or so in, I got the message about the server closing the connection. The console window was still scrolling when this happened. I'm assuming…
I got scanned by the Florida address last night also. Apr 16 10:18:52 kiwisdr kiwid: 6d:19:54:37.828 01.. 0 58.59 kHz WF z8 "kiwirecorder.py" 65.20.113.188 (ARRIVED) Apr 16 10:20:24 kiwisdr kiwid: 6d:19:56:10.547 .1.. 0 28125.00 kHz WF…
I had a feeling I was jinxing myself when I made that last post this morning. They have another IP. Apr 14 15:04:14 kiwisdr kiwid: 5d:00:39:59.867 0123 3 58.59 kHz WF z8 "kiwirecorder.py" 108.61.177.90 (ARRIVED) Apr 14 15:04:30 kiw…
It's been well over 10 days since I've had a WF only connection by anything other than "SNR-Measure." My receiver has been working fine and I've had no random restarts during that time. The list of IP addresses that I have logged for these…
Well I was close. It was a little over 2 days but here's a new one. Mon Mar 28 09:31:08 7d:23:49:44.193 0... 0 PWD kiwi W/F ALLOWED: no config pwd set, allow any (167.179.65.161) Mon Mar 28 09:31:08 7d:23:49:44.700 0... 0 L 58.59 kHz WF …
Thanks @jks, that would be cool. I've been monitoring my logs a lot more lately and along with giving me a better understanding of them, I've noticed somewhat of a pattern. I've been blocking the incoming IP address each time I catch them, but it …
@WA2ZKD This thread has nothing to do with blocking legit users. It's about blocking bots that are making waterfall only connections every hour taking up as many channels as they want while denying service to legit users.
