ArturPL
- ArturPL
- 3,047
- 4
This map simply works like that, it is a deliberate setting so that in the case of a high density of receivers in one location, not one pin is visible, but all of them, hence the spread of up to 20 km
ADMIN PANEL, WEBPAGE TAB, Additional HTML/Javascript for HTML <script type="text/javascript"> document.cookie = "last_nr_algo = 3"; </script> value 1 will enable WDSP and 2 will enable LMS well, I just noticed that it…
cutting out the IP 47.251.0.0/17 helps with this botnet
Do you have an ultrasonic air humidifier with built-in power supply at home? Mine generated identical double stripes in standby mode, which appeared several dozen minutes after turning off the steam. The fog generator board itself only made white no…
I have a different problem, so I create DX points using existing labels in the DX window, calling the functions Left mouse button + shift. When creating a new tag in the admin DX tab, starting from the top by pressing +, it creates 3 and sometimes 4…
I'll add myself to the list.
Based on PSKreporter.info statistics, especially on weekends, apart from the most popular ones, there are a lot of ROS, PSK31, SIM31 in use, which I use myself.
The photo is for illustration purposes only, I bought versions with 220uH coils, 4A version
https://forum.kiwisdr.com/uploads/045/I12XLCDNDRJY.jpg Meanwell MDR-10-5 https://forum.kiwisdr.com/uploads/290/SVRRZ3SN7QCE.jpg Meanwell MDR-10-5 + EMI https://forum.kiwisdr.com/uploads/632/SATHJFSMHS5H.jpg
OK thank you
Hi I'm making a backup, but I get this message at the end. V1.630 Debian 8.11 tested on 2 receivers which work without any problems https://forum.kiwisdr.com/uploads/361/59AF1EGMUFA1.jpg is it ok or not?
It looks so good that I already know what I will buy soon... I'm waiting for availability
If you have the opportunity to buy it, I recommend the MLA-30 antenna (just don't buy the worthless MLA-30+), which works well in my district polluted with switching power supplies. Additionally, a 12-14 m glass fiber rod, a steel auger to be screwe…
In a nutshell, it's a kind of FT8 extended with an additional option to exchange text information. Looking at the popularity of the JS8Call software on PSKReporter, it occurred to me that since JS8 is an FT8 clone, it will be easy to adapt it. On OW…
Thanks for your effort, now it works perfectly
CONSOLE: open connection root@kiwisdr:~/Beagle_SDR_GPS# df . Filesystem Size Used Avail Use% Mounted on /dev/mmcblk0p1 3.5G 1.6G 1.8G 48% / root@kiwisdr:~/Beagle_SDR_GPS# all cards are 10class 16gb
BBG
Debian 8 (still) previous copy around 1.52 or 1.53
https://forum.kiwisdr.com/index.php?p=/discussion/comment/15799#Comment_15799 Sorry I'm only replying now, but the holiday trip has been extended. When I wrote about looping, I meant that v.1.592 did not preempt slots and instead kiwi from proxies t…
Unfortunately, preemption doesn't work if Kiwi uses a proxy service, a redirect loop ensues.
It works flawlessly, I connected MULTIPSK with FT8 decoding over the virtual cable, in Kiwi I adjusted the SNR to -21 so that the values were similar. Today, after about 12 hours with FT8 running, I came across PSKreporter: at SWL/PLONSK (7135 repor…
yes but drawing with lines or RGB points in this window didn't give me a satisfactory waterfall look, unless there is some other way that I don't know about?
I'm reviving this thread because I wanted to set such a color map https://forum.kiwisdr.com/uploads/007/R0RFXATJHXQX.jpg how to create it? my fiddling with the colormap tab doesn't have that effect. Or maybe it would be possible to implement such a …
Only today I had the opportunity to listen to how FM works after the update, there is power! Great piece of work, thank you
If it is configurable, the default 6kHz should be ok. Generally, in amateur bands, narrow FM (marked as NFM/NBFM) has a width of 2.5kHz (FM-LINK repeater networks in the 70cm band) and wide FM (WFM/WBFM) has a typical deviation of 12kHz. If that's n…
They got carried away by the price 😮 ! at the current exchange rate of $970, I bought a fifth unit from them in October for $480
A while ago I noticed 2 sessions from china on my kiwi with 118-146MHz band one had its IP 49.77.180.23 and according to what the USERS window showed, it was listening on 241.368.CW ? the second 127.0.0.1 around 130200 After blocking 49.64.0.0/11, i…
Chrome menu: Settings/System Use hardware acceleration when available or left Ctrl and + on the numeric keypad check if Zoom is at 100%
Hi Is it possible to add message YOUR IP IS BLOCKED ON THIS RECEIVER for local blacklist? What if you could add a reason for the block to be displayed to the user, like in the old days on IRC? ;) regards
https://forum.kiwisdr.com/index.php?p=/discussion/2779/10khz-tuning-steps Here's my example: In the admin panel, go to the DX tab. Create a new bar https://forum.kiwisdr.com/uploads/336/HJVI0Q0YULSI.jpg https://forum.kiwisdr.com/uploads/236/S51WBMDC…
