                ok Thanx for the help mate ive sent the email for a new key, taking the kiwi and heading out to the new location i'll let you know what happens
                ok gotcha i am about to change the ports now to 8074 restart the kiwi and request a new key via email move the kiwi to its new location and set the rest up from there Question, if for any unseen reason i have to have them share an antenna (via spli…
                Hello Jks, "unique port number (typically 8074). So you would first make that change on the second Kiwi and restart" Are you referring to the internal/external port setting under the Network tab? "Does the first Kiwi use the prox…
                Hello, In the next hour or so i will be relocating the Kiwisdr from current location to permanent location where it will be connected to a router which already has a kiwisdr connected to it and also it will have its own antenna connected. I'm worr…
                Jks, thanx for your help, i am really pleased with the outcome and hopefully in the upcoming months will be looking at setting up a permanent kiwisdr at the radio club with a better antenna setup.
                JKS, :) i believe it is working fine now and online on sdr.hu after i clicked the (re) register button thank you so much for your help guys
                Jks, "" So try clicking the "click to (re)register" button again and see what you get"" Status:New account, registration successful sorry i just saw that part of your message and i clicked
                Hello jks & Powernumpty, thanx for your responses... Jks "Status: Reverse proxy enabled and running" i have attached a screen shot with this post if you would like to have a look at the status. Also, the unique API Key was received …
