eckrot
eckrot
1,395
4
  • periodic drop-out with ver. 1.240 ? [fixed in v1.241]
    some addition: it only affects the audio and s-meter, the waterfall is not distorted.
    Eckhard
    on4lao
  • Increasing Audio Quality
    That sounds great already! Would be nice to have that option also in one of the next updates!
    elitedata
  • Wide band, vertically interleaved interference
    No - there's no filter for that kind of wideband garbage! The only way is not to use this nonsense ... to feed HF on unshielded cables with undefined impedance and thus unmatched means that a lot of HF is radiated.
    However, it's also often used here in Germany. The industry lobby did a good job in Brussels to get CE for a technique that never can meet any limits.
  • Update Problem [fixed in v1.332]
    since two days I get an error when trying to update my Kiwi:
    UPDATE: force update check by admin
    Thu Sep 12 15:23:25 19:54:53.489 0.. UPDATE: checking for updates
    Thu Sep 12 15:23:26 19:54:54.515 0.. UPDATE: version changed (current 1.329, new 1.331), but check only
    Thu Sep 12 15:23:26 19:54:54.518 0.. task update_task:P3:T24((1000.000 msec) TaskSleep) exited by returning
    Thu Sep 12 15:23:29 19:54:57.055 0.. UPDATE: force build by admin
    Thu Sep 12 15:23:29 19:54:57.058 0.. UPDATE: checking for updates
    Thu Sep 12 15:23:30 19:54:58.085 0.. UPDATE: version changed (forced), current 1.329, new 1.331
    Thu Sep 12 15:23:30 19:54:58.088 0.. UPDATE: building new version..
    Thu Sep 12 15:23:30 19:54:58.090 0.. rx_server_user_kick rx=-1
    Thu Sep 12 15:23:35 19:55:03.112 0.. LRUN update_task:P3:T24((1000.000 msec) TaskSleep) (1000.000 msec) TaskSleep 5027.663
    Thu Sep 12 15:23:37 19:55:05.568 0.. 0 5689.00 kHz usb z6 "79.253.53.133" Freiberg, Germany (LEAVING after 1:22:00)
    Thu Sep 12 15:25:12 19:56:39.963 0.. UPDATE: build error, no Internet access? status=0x00000200 WIFEXITED=1 WEXITSTATUS=2
    Thu Sep 12 15:25:12 19:56:39.966 0.. task update_task:P3:T24((1000.000 msec) TaskSleep) exited by returning
    It says not connected, but it is. My Kiwi can be accessed from internet, it works without any issues.
    Any idea what can be done to solve this?
    Thanks!
    Eckhard
    IZ3EAW
