loststation
- loststation
- 69
- 3
43 characters. [fixed in v1.432]
I discovered that if you enter more than 42 Russian characters in the "your name or callsign" field (too lazy to check others, but there are no problems with English), you become invisible. No, everything is still visible in the logs. But in «admin -> status» nothing is visible. Also not visible in rx0 ... 4 for others. This is not very convenient. Probably need to limit the number of characters. I have not yet tested if it is possible to inject a script there in order to break something.
66.666 MHz TCXO for KiwiSDR. Jamming/spoofing GNSS.
Please recommend me a 66.666 MHz TCXO for KiwiSDR. I suspect that there is GNSS jamming/spoofing in my region. Therefore, precise frequency trimming is impossible. Signals are often not decoded on any of the GNSS antennas. It just started recently. I searched the internet and couldn't find them with an accuracy of even 1 ppm. Thanx all.
Soldered ipex1 to kiwisdr. Connected synthesizer with VCXO 0.5 ppm (from Aliexpress). Works well. I heated the synthesizer very much - the frequency is stable. SMA connectors on the synthesizer are not very good quality. It is better to solder directly. The synthesizer was calibrated using a 9996 kHz time signal station.
Thanks for the advice. I've seen these synths before but thought they were crap.
