loststation
- loststation
- 67
- 1
Its OK now. Tnx!
Yes. KiwiSDR 2 is more important.
By the way, judging by the log, sometimes such connections are kicked as incomplete. And sometimes not. And then it's a big problem. Now I have blocked the ip blocks from which such connections come. Otherwise, one user on the first sdr will not all…
I had free time and I found out what was going on. Since there are a lot of http requests to open a site with kiwisdr (more than 40), VPN Cloudflare opens some of the requests from other ip. It turns out an interesting situation, described above. An…
https://forum.kiwisdr.com/uploads/455/25GDY1URB5V1.jpeg The correct Zoom is in the WF connection and the correct frequency is in the RX1 connection, when connected via this VPN. And further. If such a WF connection exists and all channels are busy, …
I will gladly purchase such a receiver in the future. And not even one. Indeed, there are enough problems with other receivers. Kiwisdr is my first receiver that completely suits me. And my friends too. But the trouble is that other people want to l…
And will it work? The cunning "spy" will simply cut out this script locally. You need to adapt this script on the server side.
I have responded to you by email. The script for blocking TOR is very simple. The TOR project itself gives out what needs to be blocked. Blocking a VPN will be more difficult. That is, it will be the eternal addition of new subnets. It is advisable …
Short waves have their own specific propagation. Even because of the silence zones, they will use other receivers. At the frequencies of "zenith" communications, in principle, long-range reception is impossible. Yes, they have their receiv…
+1. PERMANENT scanning should be discussed with kiwisdr owners. Listening to military radio networks and those indirectly connected to them should be limited. It doesn't matter which spy is hiding behind the next VPN. Now is a very difficult time. T…
I doubt. Spying can also be directed against your country. My long observation of these spies led me to the following thoughts: they will exploit your receiver, including for bad purposes; and harmless schoolchildren will occupy all channels for a l…
8897 — military frequency. Russian Air Force. In addition to ordinary users, it can be different spy curators from different countries. Most of them are always hidden behind vpn, tor and non-public proxies. Also seen scanning frequencies from ENIGM…
I think it's real. But John once wrote that he was tired of figuring out what the guys from Apple had once again broken. With ios 13 they have changed background work.
Almost always it is problems with the Internet. Buffer underrun on the user side. If “underruns” are observed only for one user, while others are fine at that moment, then these are problems of a particular user. If “underruns” are observed simultan…
Due to recent events, I would suggest filtering by keywords and completely disabling the "callsign" field.
John, I also noticed that the "de-emp" function is not working correctly. 75us = 50us. There is no difference between them. I tested it on different receivers. Perhaps this problem is old. Because in version 1.402 this is also noticed. Che…
http://forum.kiwisdr.com/uploads/530/3XY0WBM9V39C.jpeg Yes, everything is fine now. From version 14, audio panning works if you enable the Modern WebAudio API. For some reason it seemed to me that the problem was related to the iOS API.
It, of course, is good. But to users of an iOS with systems is higher, than the 14th version, is better to give old WebAudio API (old code for WebAudio API?). Now I experience some difficulties. For example, the «Comp» button has disappeared. Now I …
This is a rare situation. Okay. If I have any thoughts on how to solve this, I will write to you.
I'm also interested in this. In some cases the internet can be very bad, but users keep turning on "IQ", "SAS" and turning off "Comp". The stream starts to stutter. It is impossible to explain to everyone that the exhau…
My kiwis are working horizontally on metal racks without any cases. There is a lot of space top and bottom and on all sides, apparently that's why everything is fine. But I would not recommend repeating after me. I'm just interested in such tests. T…
Yes, you understand correctly. This is a longstanding problem. Alternatively (kludge), you can catch the output "Sorry, the KiwiSDR server is too busy right now (4 users max)", if it somehow miraculously happened, and force a redirect.
My kiwis are working without fans and cases. The house where they are installed is in the field (no ventilation). The air temperature inside the house, reaches +45 degrees Celsius in summer. The second year, everything is fine. I'm thinking of addin…
If you manage to run LMS Filter not on Beagle - it will be gorgeous. But let the existing LMS Filter work in the same variant as now. Let them be available at the same time. Only the option using Beagle resources will not be available for everyone.…
acq - "yes". GPS antenna connected. GPS reception marginal or average. (Image) About FPS: I meant the total value, of course. Not the first day an engineer :) Yes, I suspected that it was GPS. And immediately turned it off. In a e-m…
@Powernumpty, hi. I found out that LMS Filter affects all versions. Written above in the text. Am I comparing with older versions? More on this below. Because LMS Filter is not the only problem. Just in recent days, 2 comrades came up right away …
I launched 2 kiwisdr with different software versions: sdr3.tambov.gq (1.358) and sdr4.tambov.gq (1.295). For the test. So as not to disturb users on sdr and sdr2. They are not yet connected to the antenna. If 2 users are connected to the receiver w…
