HB9TMC
- HB9TMC
- 5,370
- 16
CPU Loading for Thermal Test
Xmas spectrum decoration
LED RFI
Problem with massive RFI after changing router
@W9SPY
You could try using another power supply at the router (maybe the one from the old router). Just make sure it has the same voltage and polarity and an appropriate amperage rating.
Using a _non_ shielded ethernet cable may also help. (The BBG ethernet shield is connected to antenna ground. And some routers ethernet shields are connected to their PSUs minus pin) -
QiwiQ a KiwiSDR client for Android: looking for feedback, testers and comments
