G4DYA
- G4DYA
- 1,236
- 5
Flatness of KiwiSDR response < 500 kHz?
I've done some measurements on the frequency response of the Kiwi below 1 MHz. Using a -53 dBm tone (S9+20) from a calibrated signal generator, I got -53 dB on the S meter down to 50 kHz. It rolled… (more)
Combining/Diplexing Antennas to Single Kiwi
I'm using a diplexer to combine a Wellbrook loop with a 27m horizontal terminated folded dipole (TFD). The crossover frequency is about 1.7 MHz. (I found the TFD marginally better on 1.8 MHz.) The… (more) -
I'm attempting to provide cooling for a BBAI in a Seeed case. Without the end plates, two 5V 25mm fans side-by-side works well.
First, I installed the AI but didn't use star washers next to the board -… (more) -
The BB version seems to be over-riding the Kiwi's network settings at boot and using DHCP regardless of whether it's configured for DHCP or static. If you're using a non-NATted static IP this can be… (more) -
GPS antenna alternatives
On second thoughts, I don't think my antenna is going deaf at times. The Kiwi seems to struggle to acquire sats when the server has been running for a few hours. Last night it had 11-12, but by this… (more) -
This is what my shadow map looks like after 18 hours. As expected, there's not much low-elevation stuff in some directions because of trees. In other directions, where the optical horizon is 20+ km… (more) -
Opinions needed: Ham radio digital modes -- what's currently being used?
Pactor - no FOSS decoder AFAIK, but specification is open: https://www.p4dragon.com/downloads.html (under Documents).
FreeDV - little activity outside activity periods, but there seems to be quite a… (more)
