- Powernumpty
- 5,458
- 29
kiwi cluster
I still think the mid-plate build is a good route for the AI. (if not in the original case)
Yellow for Kiwi+AI, Green for AI. Purple just to hold the lower 6x40x50mm plate on (holes all wrong for best heat transfer without distorting the plate here)
Red not used.
60mm Kapton tape over the purple holes (with screws) and entire length of the plate, 0.8/1mm fibre washers under the KiwiCape.
Only thing to watch for is the DC socket pins, might want to notch the plate there.
I just haven't worked out an inexpensive way to put that sort of plate in the proper case getting the heat out but not having to modify the shell. Obviously depending on the amount of material in contact it still needs some air movement but many times less than small heatsinks.
Plus I do believe there are noise gains to be had, don't have hard figures just gut feeling.
No USB Port Power on BBG
I have found the MLA-30 didn't work powered from the BBG USB port here but I had assumed that was some failure of the design rather than no supply to the port (will have to go get one and check..) .
As the power injector for the MLA has a 5V-12V step up I didn't try again seeing that as a bit of an issue for HF. If you want to use it with the boost I'd split out the 5V before the Kiwi and try it there, the other advantage of doing it that way is some filtering between the MLA boost switcher and the RF side.
Personally I would use another Bias-T and feed a linear voltage to the MLA avoiding the boost, it would probably run from a 9V battery that way.
73 Stu
F****r! QRM (not rude btw)
OV display time adjustment needed
Two deaths in the family
Always good to hear it worked in the end!
That Beagelbone voltage dip thing has caught a lot of people but the general power management and control has probably saved more hardware and installs than we will ever know.
I can still vividly remember the shockof discovering I had not managed to kill my Kiwi with serious over voltage. I corrected the voltage it just went on without holding a grudge. It's that sort of event that reminds me there are still some things available that have been engineered not just built.
Why is it not good?
I know feeding 5.3V to the Kiwi sounds a bit agricultural but I have unintentionally fed much more than that into the Kiwi (not Beaglebone direct) over an extended period without issue.
Unless you are going to use sense wires in production I'd tweak the supply up to that. A good few of those who post on the forum set the supply above ~5.2V to reduce the chances of issues caused by brown out as described in the quick start. There is DC filtering and traces before it gets passed to the BeagleBone.
Power the lambda on, tweak to 5.2-5.3V, connect only one Kiwi, report back. -
Thursday I noticed my WPSR results and spot ranking had tanked, I check a receiver and there was an almighty level of QRM, checked the noise charts and spotted that it started at around 8:15 the previous evening (Wednesday).
I rotated the Wellbrook loop but it was already nulling in roughly the right direction so the signal was large. Here is a screen dump from a CB vertical.
As I have been through this many times here I often feel like just giving up and finding another hobby but after a few misserable hours I figured use the S Meter extension and gather evidence.
All through Thursday, Friday and today really bad though different patern to the first day or so.
Checked after running for nearly eight hours today and it had gone off!
By now I had taken the Wellbrook on an extension coax to a number of points so that I could identify it was coming from one particular house (who I have only spoken to once when they moved in).
Despite previous wasted time approaching neighbours about this sort of problem I knocked on the door, they were great.
Turns out it is a cheap battery charger (£18) in a shed being used to charge, and desulphate by pulse, a lead acid vehicle battery.
Don't buy this charger type please, if you see them kill them with fire and bury them at least ten feet deep.
Foxsur!
I said I'd try to sort him some filters for tests and lend him another charger but I might just give him my half decent branded one made back when compliance was a thing, can't face this level of junk again. -
One for Rob (no follow up needed),
Checking my Grafana plots, 40m together with 60m were virtually a straight line, all the others looked normal.
Long story short I had a -1000dBm/1Hz recorded at the same time on those two bands so the "Auto" scale was doing it's best to keep everything in view.
1:36AM was the exact moment we had a fairly local, singular, lightning discharge.
I am somewhat impressed that it caught it, equally disturbed that all my Kit was connected to the antennas at the time.
Listen together with another user
Project needs a "Thermal Cape"
I've ordered some bits as my scrap box only has a couple of heat pipes and both need a lot of work, would get round the space issue though.
This is just waiting for some themally conductive double sided tape plus a pad for the PMIC and a bit more inspiration on physically retaining at the network end.
