- WA2ZKD
- 16,165
- 14
Kiwirecorder 101
Perhaps this helps
Usage: kiwirecorder.py [options]
Options:
-h, --help show this help message and exit
--log-level=LOG_LEVEL, --log_level=LOG_LEVEL
Log level: debug|info|warn|error|critical
-q, --quiet Don't print progress messages
-k SOCKET_TIMEOUT, --socket-timeout=SOCKET_TIMEOUT, --socket_timeout=SOCKET_TIMEOUT
Timeout(sec) for sockets
-s SERVER_HOST, --server-host=SERVER_HOST
Server host (can be a comma-delimited list)
-p SERVER_PORT, --server-port=SERVER_PORT
Server port, default 8073 (can be a comma delimited
list)
--pw=PASSWORD, --password=PASSWORD
Kiwi login password (if required, can be a comma
delimited list)
-u USER, --user=USER Kiwi connection user name
--launch-delay=LAUNCH_DELAY, --launch_delay=LAUNCH_DELAY
Delay (secs) in launching multiple connections
-f FREQUENCY, --freq=FREQUENCY
Frequency to tune to, in kHz (can be a comma-separated
list)
-m MODULATION, --modulation=MODULATION
Modulation; one of am, lsb, usb, cw, nbfm, iq
--ncomp, --no_compression
Don't use audio compression
--dt-sec=DT Start a new file when mod(sec_of_day,dt) == 0
-L LP_CUT, --lp-cutoff=LP_CUT
Low-pass cutoff frequency, in Hz
-H HP_CUT, --hp-cutoff=HP_CUT
--fn=FILENAME, --filename=FILENAME
Use fixed filename instead of generated filenames
(optional station ID(s) will apply)
--station=STATION Station ID to be appended (can be a comma-separated
list)
-d DIR, --dir=DIR Optional destination directory for files
-w, --kiwi-wav Use wav file format including KIWI header (GPS time-
stamps) only for IQ mode
--kiwi-tdoa Used when called by Kiwi TDoA extension
--tlimit=TLIMIT, --time-limit=TLIMIT
Record time limit in seconds
-T THRESH, --threshold=THRESH
Squelch threshold, in dB.
-g AGC_GAIN, --agc-gain=AGC_GAIN
AGC gain; if set, AGC is turned off (can be a comma-
separated list)
-z ZOOM, --zoom=ZOOM Zoom level 0-14
--wf Process waterfall data instead of audio
--snd Also process sound data when in waterfall mode -
New Station in Maine
Ionosonde
If you do a full freq look at the Kiwi WF you can often see the chirp sweep go by. I'd like to be able to pick a chirp TX site by name name, Millstone Hill for example, and knowing it's start time, be abe to ID that sweep that goes by. The highest freq seen would indicate the MUF for it at the Kiwi RX site. -
it is now http://rx2.wa2zkd.net and is on sdr.hu as well -
http://142.0.103.74:8073/ is OTA -
GPS RSSI vs. C/N0 vs. -dBm
Suggestion and comments on GPS please [resolved, see list of improvements]
My project for tmrw is to use a Spectracom GSG-6 GPS simulator/generator to map actual signal strength at the Kiwi GPS input to reported RSSI. Report to follow
https://spectracom.com/products-services/gnss-simulation/gpsgnss-simulators?gclid=CjwKCAjw2MTbBRASEiwAdYIpseYAdL4X4Yesk-UGnJ_EYn9Hags3PRNiwBCbjQr8x5DRX_YVIZQ5WxoCTQEQAvD_BwE -
Interesting signal 16115 MHz
ERP the result of antenna gain I'll guess. Rockwell-Collins has a WBHF waveform that goes to 48 KHz. http://www.hfindustry.com/meetings_presentations/presentation_materials/2012_sept_hfia/presentations/RC_WBHF_UK_Trial_2012.pdf
