36,263
640
  • v1.391,392,393,394: New noise blanker and filters
    From the CHANGE_LOG file:
    v1.391  May 23, 2020
        User interface changes:
            SAL, SAU mode passband image will only show single sideband (just like LSB, USB).
            Ctrl/alt-click on mode button toggles modes backwards (most useful with SAM modes).
            Same works with keyboard shortcuts, e.g. ctrl/alt-A toggles SAM modes backwards.
        Noise blankers and filters:
            Reworked the audio tab user interface to support multiple blanker/filter algorithms.
            New algorithms planned but not yet available are greyed-out in the menus.
            From Warren Pratt's wdsp package added the variable-leak LMS algorithm.
        Merged Howard Su's RPi changes.
            Note: RPi is not officially supported by KiwiSDR. Ask for help on the KiwiSDR forum:
                http://forum.kiwisdr.com/discussion/1986/port-kiwisdr-to-raspberrypi-3b
        Bug fixes:
            Audio recordings made in SAS (synchronous AM stereo) mode now work.
            Fixed problem with ITU region 2 Kiwis and shift-clicking waterfall in 75/80m band segment.
            from lazywalker: fixed problems with frequency memory and reload value when transverter offset used.
    rz3dvpPowernumptyWA2ZKDChrisSmolinskiLX1DQhowardsuLonecrowHB9TMC
    v1.391  May 23, 2020
        Bug fixes:
    v1.391  May 23, 2020
        Bug fixes:
    v1.391  May 23, 2020
        Bug fixes:
    v1.391  May 23, 2020
        Bug fixes:
    Just change the hardcoded "dtb-4.14-ti" to "$(DIR_DTB)". That's what I've done for the next release.
    iw2nkerz3dvp
    iw2nkerz3dvp
  • What is the status of the WSPR background and autostart features? [added in v1.181]
    Sorry (for those of you old enough: )
    Fix coming later today.
    k5mo
  • Kiwi Offline Due To CGNAT
    Hi Mark,
    This is a common problem, so you're in good company. I have emailed you two API keys for your Kiwis. Just enter them in the appropriate place on the connect tab of the admin page with the hostnames of your choice (presumably "emeraldsdr" and "emeraldsdr1"). Make sure to change the menu item at the top of the page to say "reverse proxy". Then use the restart button on the admin control tab.
    The DDNS becomes irrelevant when using the proxy. Your hostnames will be emeraldsdr[1].proxy.kiwisdr.com:8073 (note: always 8073)
    cathalferriso00scorpion00o
    Hi Mark,
