- jks
- 36,739
- 670
About Python KiwiClient [Kiwi API question]
The bandwidth available via the API is quite narrow (only a few narrow IQ streams at once.)
Only for the audio. Waterfall is completely separate. How is this not understood after all I've written about it? E.g. https://forum.kiwisdr.com/index.php?p=/discussion/comment/21295/#Comment_21295
Wide-bandwidth mode (relatively speaking) supporting SDR++ is/was an experiment. It is not being worked on at present. Too much other work of immediate impact to customers going on.
Direct access to S Meter and Spectrum data
Well, now hold on. You should have mentioned your exact application at the beginning.
Something the Kiwi does do is allow precise GPS timestamping of the audio stream. This is how the TDoA direction finding application is able to work. Now post-processing the audio, extracting the timestamps and synchronizing the audio samples from geographically dispersed Kiwi is not a trivial task. But it is essentially what TDoA does.
So if your goal is to measure time-of-flight of LF/VLF static crashes (a la Blitzortung.org) then there might be some hope. But it will take some moderately complex programming.
OK how have I locked only Ham Band Spectrum & Reception
Ha ha, okay. Not to worry. See our documentation here: http://kiwisdr.com/info/#id-user-marker-masked
Probably in the admin "DX" tab you used the red buttons import
JSONor importCSVon the downloaded files mentioned in the document.I guess I'm going to have to add a file in that document that will put everything back the way it was, lol.
v1.818
From the CHANGE_LOG file:
v1.818 August 9, 2025
Fixed problem where connections incorrectly originate from the local 127.0.0.1 loopback address.
When the local proxy service client (frpc) running on the Kiwi forwards packets to the
Kiwi server they will always have the IP source address 127.0.0.1. This occurs because frpc
and the server are running on the same computer. To not lose the actual IP address of the
person connecting frpc puts that IP in a special HTTP header. Well, for some reason, the
version of the Mongoose web server we use occasionally drops those special headers.
The root cause could not be found. But some time ago we ported a much more recent version
of Mongoose to the Kiwi and it doesn't have this problem. So the fix is to simply start
using this newer version.
Also, code was added to specifically reject forwarded connections with the special header
containing a local or loopback addresses. This might possibly affect private proxy setups,
like those using Tailscale or Nginx etc, if they incorrectly use a local or loopback in the
HTTP header. You can disable this specific change (but not the Mongoose upgrade) by going to
the admin "update" tab, bottom of the page, and setting "Disable recent changes?" to "Yes".
The SNR strong, wide-band signal filter has been withdrawn.
v1.816 breaks all browsers except Firefox, LibreWolf et al [update: fixed in v1.817,818]
Bug found. My fault (always is). But I'm not going to be updating Mongoose 5 => 7 for a while. Due to the @bwilson issue and possibly others. Too much else of higher importance going on right now..
Some servers always disconnect after 10 seconds with kiwirecorder.
These Kiwi most likely have the setting "Number of simultaneous channels available for connection by non-Kiwi apps" set to "None" (admin "connect" tab).
The algorithm for determining if a connection is a "bot" connection takes a little while to run (about 10 seconds). And one consequence of this is the behavior you describe. I tried this myself just now to confirm.
Unexplained Restarts [auto overnight blacklist updates]
Almost certainly because I've been updating the IP address blacklist and you have automatic blacklist downloads turned on.
On the admin status tab is a list of all possible reasons for a nightly restart. The last item in that list "Network tab: Automatically download IP blacklist" is probably set green in your case (this is the default). I can't remember if there's a specific log message when this occurs or not.
Hackers be hacking..
kiwisdr2 router problems [fixed, board separation]
So the problem here was a Kiwi purchased from a distributor that was old enough it didn't have the two boards (Kiwi, Beagle) held together via the two nylon standoffs. Vibration in transit was enough to separate the two header connectors such that the Kiwi board was not seen by the Beagle. The Beagle itself was working fine.
Re-seating the Beagle onto the Kiwi board was all that was necessary to get it working. But it took us a while to realize this had occurred.
