- jks
- 36,724
- 670
HF Broadcast Schedules
It's buried in the bug list, but there is an entry that says:- Use info from public databases, e.g. shortwave broadcast schedules (EiBi)
WSPR and who is logged on
DRM demod? [yes, external app Dream now working!]
"Initial mode" & "Initial BCB channel spacing" [fixed in v1.150]
Ugh. You are absolutely correct. Looks like I broke admin page menu select callbacks when I did a code cleanup a little while ago. I'm surprised no one else has complained about this until now. It affects 8 different menu selects on the admin pages. I'll release a fix for this right away. Thanks for mentioning it! -
Suggestion - insert google analytics code from admin panel
Sound recording from multiple opened browse windows for diversity reception?
You can see all the current options by doing: python kiwirecorder.py --helpI didn't write this code, and I don't know python, so requests for improvement should go to the original author: https://github.com/dev-zzo/kiwiclient -
@zfyoung,Your original post mentioned diversity reception, but also IQ mode. What exactly did you have in mind that was IQ-related? Were you thinking of traditional frequency diversity where kiwirecorder would open two connections on two different frequencies but merge the mono audio from each into a 2-channel file? (as L/R stereo) Or something more complicated? -
Aww, I'm such an idiot. The answer is so simple. The passband isn't wide enough! When you click the IQ button on the Kiwi it sets IQ demod mode, but also sets a default passband. But that's just how the Kiwi user interface works.With kiwirecorder when you change the mode with "-m iq" the low-level command it's sending on the web socket only changes the mode. It doesn't know anything about the passband. You'll get whatever the last passband was. The default for a new Kiwi connection is USB 300 - 2700 (2400 wide).This is of course not what you want with IQ mode. So try something like:python kiwirecorder.py -s fenu-radio.ddns.net -p 8073 -f 3965 -m iq -L -5000 -H 5000Which sets a DSB passband from -5 to +5 kHz for use with DRM. Using this I was able to feed the recorded file to Dream with no problems decoding at all.
