Random Shutdowns of Kiwis [don't use the previously recommended Jameco 1A power supply]
I have two KiwiSDRs. For some unknown reason they both randomly shutdown together. They have separate power supplies. There is no pattern to the shutdown that I can find.
Does anyone else have this issue?
Jim Gay
wa6our
Jim Gay
wa6our
Very important: what is the state of the single "power" LED to the right of the Ethernet RJ45 connector after shutdown? (opposite side of the RJ45 from the 4 other LEDs) Is it still on or is it dark? This tells us if it is a software halt or a shutdown due to the Beagle power controller shutting down.
When you say shutting down "together" do you mean you've observed them shutting down exactly at the same time or you've happened to catch them after-the-fact both in a shutdown condition? (i.e. they could of shutdown at separate times in the past but you didn't notice this event). It is an important clue if you actually observed them shutting down simultaneously.
I'll look at the logs and see if anything looks suspicious.
It's more important than ever to know the state of the power LED the next time it happens.
If the power LED is not lit then this is almost certainly a power quality issue. What kind of power supplies are these? It's winter there, right? What's your opinion about how these supplies will hold up with brief line voltage disruptions you might encounter in winter (i.e. the ones where the lights flicker very briefly).
Just look at the debacle we went through yesterday with power quality. Ethernet failures due to bad power. Something we've never seen before..
http://forum.kiwisdr.com/discussion/comment/8733
Here is what the messages file shows:
Feb 17 11:55:01 kiwisdr kiwid: 23:45:14.816 .... UPDATE: version 1.380 is current
Feb 17 11:55:49 kiwisdr kiwid: 23:46:03.313 01.. 0 880.00 kHz am z0 "80.229.148.164" Hampstead, United Kingdom (ARRIVED)
Feb 17 12:37:12 kiwisdr kiwid: 1d:00:27:26.701 01.. 1 22.71 kHz cw z13 "24.20.199.5" Sunnyside, Oregon, USA (ARRIVED)
Feb 17 12:38:05 kiwisdr kiwid: 1d:00:28:19.440 01.. 1 22.71 kHz cw z13 "24.20.199.5" Sunnyside, Oregon, USA (LEAVING after 0:00:58)
Feb 17 12:41:09 kiwisdr kiwid: 1d:00:31:22.977 .... 0 6000.00 kHz am z6 "80.229.148.164" Hampstead, United Kingdom (LEAVING after 0:45:25)
Feb 17 13:59:51 kiwisdr rsyslogd: [origin software="rsyslogd" swVersion="8.4.2" x-pid="437" x-info="http://www.rsyslog.com"] start
Feb 17 13:59:51 kiwisdr kernel: [ 0.000000] Booting Linux on physical CPU 0x0
Feb 17 13:59:51 kiwisdr kernel: [ 0.000000] Initializing cgroup subsys cpuset
Feb 17 13:59:51 kiwisdr kernel: [ 0.000000] Initializing cgroup subsys cpuacct
The Kiwi plus BBG draws over 1A and peaks approaching 1.5A
1A is simply not enough, it might run while idle, but will fail under load or momentary glitch as mentioned.
It's too bad because at $12 or whatever it was that Jameco linear supply was a steal. Too bad they didn't have a 2A version. Those kind of linear DC plug-packs are now technically illegal to import into the USA (and elsewhere probably) due to stupid efficiency requirements. The industry is forced to only offer SMPSs and our hobby consequently suffers. Instead you have to spend $60 on an open-frame linear or roll the dice on eBay.
Thanks for the information.
