V1.92 Fax decoder
                    Hi John,
                            The beta Fax decoder in V1.92 is very impressive even in its current form :-)
I realise that there is much more work to be done, but I tried the record function and I don't see a thumbnail when I press stop and when I click on the missing thumbnail image space I just get a blank image page.
Checking the size of the stored file fax.ch2.png shows 0KB.
got a tension to fiddle around the FAX decoder today and would like to share my notes and suggestions on its work so far.
Yes, the images are slanted, but I understand the decoder is in an early stage of life and it might be fixed in the future.
But here are a few less obvious bugs I've encountered:
1) It seems I cannot run the "recorder" for too long, eg. 20 minutes or more, or, when I click the image, when it seems to be ready to view, I crash the server
2) ... it depends. If I stopped decoding that image before hitting the record button, then, after I end the recording, all I get is an empty PNG image, 0 bytes of size. That's regardless of whether I start decoding during the FAX or not. I think this is the reason why some of us get nothing instead of decoded images at times.
3) On the plus side, clearing the decoder's buffer while recording the
FAX doesn't result in losing anything of actual resulting picture.
4) A few Japanese Fishery stations have FAX transmissions scheduled too. They're not listed in http://www.nws.noaa.gov/os/marine/rfax.pdf and it's a bit hard to obtain information on them, but I can tell JFX Kagoshima broadcasts a chart on 8658 kHz (tune to 8656.1 USB) eg. at 18:00 UTC. Full schedule, as received by somebody via FAX itself, is as follows: (note that all times are in JST = UTC+9h)
By the way, could anybody confirm the status of BMF in Taiwan, and CBV and CBM in Chile? They are all listed in that PDF, but, well, I haven't heard BMF for a few years and consider it inactive now. And I know nothing about Chilean stations.
Best regards,
Arnie
NOJ Kodiak is certainly active too, on 2052.1 4296.1 8457,1 (though this one is somewhat defective) at 1150z
The receiver antenna is Mini-Whip.
Fortunately, there was no usual QRM at the moment.
