IP address blacklist
                    Here is my IP address blacklist.
47.88.219.24/24 54.39.22.213/24 77.93.205.2/24 185.220.100.246/24 123.151.76.158/24 45.14.148.97/24 144.217.85.55/24 104.244.76.245/24 185.220.101.45/24 64.113.32.29/24 62.102.148.68/24 18.27.197.252/24 178.17.174.224/24 77.109.191.140/24 23.129.64.194/24 85.248.227.164/24 89.234.174.47/24 185.100.87.206/24 179.43.134.154/24 144.217.255.89/24 167.88.7.134/24 81.17.27.131/24 185.100.85.101/24 185.207.139.2/24 109.70.100.33/24 83.97.20.185/24 185.107.47.171/24 209.141.34.95/24 178.165.72.177/24 171.25.193.25/24 46.165.245.154/24 104.244.72.115/24 104.244.78.231/24 178.175.148.42/24 178.17.171.115/24 141.98.254.225/24 185.130.44.108/24 77.247.181.163/24 128.31.0.13/24 107.189.10.143/24 104.244.73.126/24 193.124.186.222/24 94.140.114.159/24 199.195.251.226/24 95.211.230.211/24 91.221.57.179/24 87.118.110.27/24 199.195.250.77/24 185.38.175.71/24 166.70.207.2/24 62.219.3.48/24 198.98.53.61/24 176.123.5.250/24 185.107.70.202/24 51.158.147.12/24 193.169.255.102/24 51.15.177.65/24 204.8.156.142/24 31.185.104.21/24 141.255.162.38/24 123.226.96.170/24 198.98.56.155/24 209.141.45.212/24 185.129.62.62/24 173.212.217.87/24
For your reference.
For your reference.
205.185.127.219/24
Always the same frequency, mode, long access.
Access many times even if kicked.
It tries to connect many times even if it is kicked automatically. (After blacklisting)
Change the IP address to access.
Sun Jan 19 03:53:35 05:04:57.028 01.. CONN: 127.0.0.1 X-Real-IP 166.70.207.2
Sun Jan 19 03:53:35 05:04:57.028 01.. CONN: 127.0.0.1 X-Forwarded-For 166.70.207.2
Sun Jan 19 03:53:35 05:04:57.028 01.. IP BLACKLISTED: 166.70.207.2
Sun Jan 19 03:53:51 05:05:12.511 01.. CONN: 127.0.0.1 X-Real-IP 166.70.207.2
Sun Jan 19 03:53:51 05:05:12.511 01.. CONN: 127.0.0.1 X-Forwarded-For 166.70.207.2
Sun Jan 19 03:53:51 05:05:12.511 01.. IP BLACKLISTED: 166.70.207.2
Sun Jan 19 03:54:05 05:05:27.040 01.. CONN: 127.0.0.1 X-Real-IP 166.70.207.2
Sun Jan 19 03:54:05 05:05:27.041 01.. CONN: 127.0.0.1 X-Forwarded-For 166.70.207.2
Sun Jan 19 03:54:05 05:05:27.041 01.. IP BLACKLISTED: 166.70.207.2
Sun Jan 19 03:54:20 05:05:41.417 01.. CONN: 127.0.0.1 X-Real-IP 166.70.207.2
Sun Jan 19 03:54:20 05:05:41.418 01.. CONN: 127.0.0.1 X-Forwarded-For 166.70.207.2
Sun Jan 19 03:54:20 05:05:41.418 01.. IP BLACKLISTED: 166.70.207.2
Sun Jan 19 03:54:34 05:05:56.269 01.. CONN: 127.0.0.1 X-Real-IP 166.70.207.2
Sun Jan 19 03:54:34 05:05:56.269 01.. CONN: 127.0.0.1 X-Forwarded-For 166.70.207.2
Sun Jan 19 03:54:34 05:05:56.269 01.. IP BLACKLISTED: 166.70.207.2
Sun Jan 19 03:54:46 05:06:08.048 01.. CONN: 127.0.0.1 X-Real-IP 166.70.207.2
Sun Jan 19 03:54:46 05:06:08.048 01.. CONN: 127.0.0.1 X-Forwarded-For 166.70.207.2
Sun Jan 19 03:54:46 05:06:08.048 01.. IP BLACKLISTED: 166.70.207.2
Sun Jan 19 03:54:54 05:06:16.212 01.. AJAX: 127.0.0.1 X-Real-IP 167.99.214.222
Sun Jan 19 03:54:54 05:06:16.213 01.. AJAX: 127.0.0.1 X-Forwarded-For 167.99.214.222
Sun Jan 19 03:55:00 05:06:22.135 01.. CONN: 127.0.0.1 X-Real-IP 166.70.207.2
Sun Jan 19 03:55:00 05:06:22.135 01.. CONN: 127.0.0.1 X-Forwarded-For 166.70.207.2
Sun Jan 19 03:55:00 05:06:22.135 01.. IP BLACKLISTED: 166.70.207.2
Sun Jan 19 03:55:14 05:06:36.290 01.. CONN: 127.0.0.1 X-Real-IP 166.70.207.2
Sun Jan 19 03:55:14 05:06:36.290 01.. CONN: 127.0.0.1 X-Forwarded-For 166.70.207.2
Sun Jan 19 03:55:14 05:06:36.290 01.. IP BLACKLISTED: 166.70.207.2
73
Phil
Phil
On the DX label edit panel it's the last entry ("masked") on the "type" pulldown. You will see the blackout in the waterfall immediately.
I suppose that this masking works on the viewed part of the spectrum hence at the end of the demodulation process.
Another more usefull feature would be a MASK during the RF_Spectrum scan , in this way also the
interfering transmissions could be left out of the successive "demodulation" process,
saving for lot of pass-band filters, etc etc.
73
Phil
73
Phil
>MASK_ing the RF spectrum during the sampling phase , hence directly at the RF stage instead of post sampling procedures
Unfortunately you can't do that.
All the processing is performed after the Analogue RF signals are sampled and converted to digital bits.
The Analogue to Digital Convertor (ADC) is a broadband device that samples everything that is presented to it.
Although there is a 30MHz Low Pass (anti-alias) filter ahead of the ADC, there is no method using the existing hardware to exclude specific chunks of spectrum prior to the ADC.
It all has to be done in code afterwards, but by this stage it's too late to chop out any signals that are at a high enough level to overload the ADC.
This is why quite a lot of KiWi admins (myself included) have added external filters in order to try and make best use of the available dynamic range.
EDIT: And now another. They seem to like to check out 5598 kHz. I'd be tempted to ask for an option to auto boot/ban any IP that tries to tune in that frequency
Although a while ago, on some receiver in Japan I think, I did myself see what looked like a bot, with the curious habit of copying my (or other users') geolocation string in the users tab, if I remember correctly. Maybe that's the same thing we're talking about with:
So there are certainly some weird things happening out there, I would know, but not necessarily anything nefarious or even interesting.
Makes me think of (5:47):
