DRM Heard
                    Here in upstate NY I have heard and decoded to audio Nigeria, Kuwait, Romania, India HF.   I have not heard even a trace on WINB or funklust
There's plenty of North Korean jamming especially on 49m but it doesn't seem to be near any DRM signals.
BTW, users may have noticed how DRM omits the 0 Hz carrier. That was a very wise move. It buys a little immunity from co-channel AM interference since an AM carrier's power spectral density is so huge compared to its sidebands.
Does Voice of Russia still exist? I read that they discontinued all shortwave broadcasting several years ago, but they're still listed in the DRM schedule. I have never seen any of them in a waterfall display, though.
https://www.drm.org/wp-content/uploads/2018/12/DRM-Transmission-in-SW-_B18_1_28112018.pdf
5995 Romania
7235 Romania
7550 India
Enough SNR to get decode to confirm DRM
at 2100Z
6030 Romania
7550 India
at 2200Z
9490 Romania
2300Z
6040 Romania
CNR: 9860, 11850, 13680
AIR: 9445 (parallel 7550?)
RNZI: 9780 (not in their online listing)
Since newdelhi.twrmon.net:8073 is back online I was able to do a band-scan at 6AM local and verify a bunch of India MW DRM. Eleven are now shown verified in the schedule.
1651-1750 5975 (unchanged)
1751-1850 11690 (ex 9780)
1851-1958 13840 (ex 11690)
https://rnz.co.nz/international/listen
6100kHz and 9950kHz are actually AM broadcasts.
Instead, DRM broadcasting is performed on the following frequencies that are not registered as DRM.
1000-1100 15410kHz ch1:English ch2:Music
1145-1330 15030kHz ch1:Chinese ch2:Tibetan
https://short-wave.info/index.php
www1.s2.starcat.ne.jp/ndxc/ (Aoki list)
The bottom half of the 10 kHz wide signal seems to consist of unmodulated carriers, always present on their published frequencies, and it may be there due to a misconfiguration on their part. I get more reliable/quicker lock if I tune up by 2.5 kHz.
IF Level: -9.1 dB
SNR: 16.2 dB
DRM mode B
Chan 10kHz
ILV L
SDC 16 QAM
MSC 64
Medium range use, multipath resistant
Services:
1. AAC (1001) SNR Tiganesti E1 EEP Audio 20.96 kbps
Diffusion exprimentale DRM par TDF depuis Issoudun
IF Level: -10.9 dB
SNR: 6.7 dB
DRM mode B
Chan 10kHz
ILV L
SDC 16
MSC 64 QAM
Protect: A=0 B=1
Services: A=2 D=0
Services:
1 AAC (1) CHINESE EEP Audio 10.48 kbps
2 AAC (2) VB / TIBETAN EEP Audio 10.48 kbps
There are a bunch of small changes in the works. I am trying to find the source of crashes in the AAC/xHE-AAC code during marginal signal conditions (most easily noticed with some of the CNR signals). This is bad because it causes the entire Kiwi server to reboot.
I have heard the following AIR local stations on DRM -
AIR Lucknow 756 khz @ 13.15 UTC
AIR Panaji 1296 khz @ 13.30 UTC
Best time to listen is just after sunset on the Delhi and Bangalore rx on sdr.hu
The DRM official site carrying frequencies of AIR local stations is the best reference for DRM in India
