BBG and some PSU problem
Hello friends,
As you probably know know, for normal start BBG board need fast +5V voltage rise from PSU, if you use powerful transformer PSU you can have problem with autostart KiwiSDR after power outage.
Info from https://groups.google.com/forum/#!topic/beagleboard/aXv6An1xfqI[151-175]: "The BBG uses the TPS65217 power management IC. Per the data sheet, it will not turn on if the applied power has a ramp of greater than 50 mSec."
I have this problem with one of my PSU's, when BBG don't start after power lost and I installed device with 10s delay for allow power from PSU and it was very helpful for me:
https://www.ebay.com/itm/LED-Home-Automation-Delay-Timer-Control-Switch-Relay-Module-Digital-display-PLC/252867596893?ssPageName=STRK:MEBIDX:IT&var=551880757238&_trksid=p2060353.m1438.l2649
Maybe this info was halpfull for something else.
73! Yuri
73! Yuri
A device like this can also provide a delay for a router (e.g. providing DHCP) to recover after a power fail properly before the Kiwi attempts to access the network. This is also sometimes an issue, although the Kiwi software startup has a built-in 30 seconds delay just for this scenario.
