The S meter values across the bottom of the Control Panel
                    What is the basis of the S meter values across the bottom of the Control Panel??
It has a much more impressive reading of 2-3 S-points now than the S8-S9 shown by my FT-857 right now.
These are both on almost the same freq. and are looking at the noise in the passband.
And this looks to be a constant relationship with a +/- 1 indeterminancy.
The FT-817/857/897 series have very poorly calibrated S-meters.
The first few S-points are less than 1 dB per division apart.
https://g8jnj.webs.com/SMETER.pdf
Of course what the S-meter value actually means when connected to a real antenna is an argument as old as radio itself..
I've heard it suggested that this has been done deliberately by manufacturers in order to make make their radios seem more "sensitive". But if so, I think it has been a terrible disservice because it hides the absolute signal and noise levels such that real problems aren't recognized and addressed. A receiver with an S meter that is accurate and can be calibrated and trusted for both signals levels and RMS noise in a known bandwidth, as the kiwi can, is a great boon to all of us, IMO.
I suggest using the kiwi to measure/calibrate the commercial radio and keeping the results handy so that useful values can be obtained.
I think the divisions could be as small as 0.5dB!!
I rather thought this with the FT-857 was so, very similar to the FT-290R. LA8AK had a very good mod for the S-meter cct in that rigo.
JKS - I won't be adjusting to match the FT-857. It so happened I moved the the 857 to the same room as the KiwiSDR and was surprised at the differences.
N6GN - So you and I are '6dB' people. The stories about different S-meters and their 'calibration' have been replayed time and time over the years, and won't be regularised anytime soon.
>When the S Meter option is selected can we have a readout in S points as well as db - This would be more user friendly
I think it would make the text too small to be useful and it's very easy to quickly read S points from the bar graph anyway.
Personally I'd ban 'S' points as they are pretty meaningless, but that's just my opinion :-)
