Waterfall filtering? [added in v1.337]
                    What about implementing some simple vertical filtering for the waterfall? I mean something that vertically blurs the graininess. Several other SDRs (e.g. mchf, ELAD FDM, ...) have it, should not be difficult to implement.
Cheers
fbx
                            Cheers
fbx
For example, if I'm at z9 looking at an AM signal, and I have a full waterfall showing in the window, and I go to z8 the visible waterfall (to me) has a better aesthetic while still showing all of the details that I've already been seeing. There's a very obvious border between the zoom levels with the new waterfall data appearing much more grainy than the old waterfall below.
Maybe an option to have the waterfall data use the next zoom in, but twice the width, for the waterfall? Would that have much impact on the processing requirements either on the BB or the browser?
I've tried the new filters, although I'm not sure if I like the end result, but that may be just me.
To my eyes the waterfall looks very 'blurry' with even the mildest settings and weak signals seem to get lost among the 'smearing'.
SDR Sharp has 'sliders' that allow you to set the waterfall and spectrum display 'attack' and 'decay' times.
This works very well, as it allows you to catch short duration signals but they remain visible for sufficient time to be easily spotted on the waterfall display, yet the random background noise is still filtered out.
I've varied a few SDR Sharp attack and decay settings as the waterfall scrolls down in the example below.
Just my observation, your mileage may vary.
I presume that this has something to do with the change in the most recent firmware, perhaps having to do default waterfall averaging? If so, a uniform shift like this is not what I would have expected with averaging. Is this an expected artifact?
Clint
KA7OEI
What happened was that the reduction in CIC filtering required to get 14-channel mode for the BBAI to fit in the FPGA leaked into the v1.337 build of the other FPGA configurations (4, 3 and 8-channel modes).
thank you for taking my suggestion into account!
Unfortunately it does not seem to work here. The slider "WF Delta" cannot be moved. Am I missing anything? I use Firefox.
Thanks
fbx
BTW what's the meaning of IIR/MMA/EMA ?
f
IIR: An "infinite impulse response" filter as nicely explained by Alex, VE3NEA: www.dxatlas.com/rocky/advanced.asp
