KYOTO News FAX 16969.1 kHz 23:00utc
                    I receive this FAX but it is odd in that it appears to  have more than one page of information printed on the page. Is there a special decoder that does 2 page FAX in one transmission?
From memory you won't get clean faxes from the Japanese stations who are using 60rpm with the KiWi decoder, but I believe they transmit English news at 19:00 utc using 120rpm which looks good.
similar to how CRT television operates.
The Japanese pages are scanned at half of this speed 60rpm, possibly because of the structure of the Japanese characters and the layout of the page.
Because the drum speed is twice the actual speed, there is a gap between each scan line, which give the interlaced effect.
It would seem that the KiWi Fax decoder overwrites the first image with the second one due to some sync / end of image signal that is misinterpreted due to the speed mismatch.
The author indeed shows that Kyodo as last HF fax news agency still transmits faxes at 60 lpm. Also he confirmed that BMF Taiwan has stopped its HF service long time ago and a good candidate for replacement in the Asia/Pacific drop down list would be XSG Shanghai.
He also made some mods to kiwifax.py in order to let it run continuously for DX station capture, suppress the log file and add some drift corrections for non GPS Kiwi nodes.
Regards, Ben
A speculative entry was added for GM-11F Ukraine (see: mt-utility.blogspot.com/2009/12/so-who-is-gm-11f.html)
That post is 10 years old. Since 1430Z is 0230 am for me could someone try listening at that time and see if GM-11F is still on the air?
https://forum.kiwisdr.com/uploads/Uploader/3d/c831a3a0669ae6949915e0f653e38b.png
I used directkiwi (https://github.com/llinkz/directKiwi) to look for possible transmissions today. This very useful Python program created by linkz seems actually not so well known among Kiwi users. By using the audio sockets only it can switch rapidly between Kiwi nodes just by clicking on the node symbol displayed on a world map GUI. Great tool for quickly checking the actual area of propagation of a transmitter as well.
Not surprisingly no trace of these transmissions around 1430 UTC anymore when I checked and the reference is probably too old.
https://forum.kiwisdr.com/uploads/Uploader/8d/fb703cc1f7629375a7a096a9e27aa1.png
It's also not been listed (that I can find) in recent ITU or IARU intruder watch (7090 kHz is in the 40 meter amateur band) bulletins, so it's unlikely, but very occasionally stuff like this does spring up again when they find another Kopek to feed the electricity meter down the back of the sofa.
