Metal Case observation
There have been numerous threads and discussions about circulating currents and spurs and noise and the like.
I note that on the Seeed metal case, one of the endplates touches the ethernet connector along one edge. Is that intentional?
The problem is that it doesn't make very good or consistent metal to metal contact.
I found that if I 'wiggled' the Ethernet connector I got better or worse noise spurs, depending upon what was touching what. In the end I soldered a brass strip between the Ethernet connector screen and the brass mesh I used to cover the inside of the end plate.
http://forum.kiwisdr.com/uploads/editor/ao/sqwxoc7s8gm9.png
