W/F and SND Bad Params
                    I'm seeing stuff like this in my logs:
Mon Jul 29 08:11:48 05:12:35.039 0... 0 W/F BAD PARAMS: sl=18 50|48|49 [2019/7/29 16:11:43] ip=47.88.219.24 ####################################
Mon Jul 29 08:12:06 05:12:53.170 0... 0 SND BAD PARAMS: sl=18 50|48|49 [2019/7/29 16:12:02] ip=47.88.219.24 ####################################
Mon Jul 29 08:12:48 05:13:35.208 0... 0 W/F BAD PARAMS: sl=18 50|48|49 [2019/7/29 16:12:43] ip=47.88.219.24 ####################################
Mon Jul 29 08:13:06 05:13:53.337 0... 0 SND BAD PARAMS: sl=18 50|48|49 [2019/7/29 16:13:02] ip=47.88.219.24 ####################################
Mon Jul 29 08:13:48 05:14:35.247 0... 0 W/F BAD PARAMS: sl=18 50|48|49 [2019/7/29 16:13:43] ip=47.88.219.24 ####################################
Mon Jul 29 08:14:06 05:14:53.334 0... 0 SND BAD PARAMS: sl=18 50|48|49 [2019/7/29 16:14:02] ip=47.88.219.24 ####################################
Mon Jul 29 08:14:48 05:15:35.278 0... 0 W/F BAD PARAMS: sl=18 50|48|49 [2019/7/29 16:14:43] ip=47.88.219.24 ####################################
Mon Jul 29 08:15:06 05:15:53.363 0... 0 SND BAD PARAMS: sl=18 50|48|49 [2019/7/29 16:15:02] ip=47.88.219.24 ####################################
Mon Jul 29 08:15:48 05:16:35.310 0... 0 W/F BAD PARAMS: sl=18 50|48|49 [2019/7/29 16:15:43] ip=47.88.219.24 ####################################
Mon Jul 29 08:16:06 05:16:53.382 0... 0 SND BAD PARAMS: sl=18 50|48|49 [2019/7/29 16:16:02] ip=47.88.219.24 ####################################
Mon Jul 29 08:16:48 05:17:35.189 0... 0 W/F BAD PARAMS: sl=18 50|48|49 [2019/7/29 16:16:43] ip=47.88.219.24 ####################################
IP back to something in Singapore.
What's this about?
What's this about?
I might start geo blocking on my router as would prefer not to see all that unknown traffic.
W/F BAD PARAMS: sl=18 50|48|49 [2019/7/29 19:22:26] ip=47.88.219.24 ######
--removed-383-lines
12hrs of this junk
SND BAD PARAMS: sl=18 50|48|49 [2019/7/30 12:15:26] ip=47.88.219.24 ####################################
Tue Jul 30 04:15:32 8d:12:53:17.283 01234567 1 W/F BAD PARAMS: sl=18 50|48|49 [2019/7/30 12:15:26] ip=47.88.219.24 ####################################
Same IP that you're seeing and another one. It's getting in the way of user access.
I don't see how this could be part of the random network scanning which happens all the time on the Internet. Someone is specifically looking at Kiwis. Like they've taken the kiwiclient code and modified it to do this driven from the list of public Kiwis. It would be interesting to see if any legitimate commands are being sent from those ip addresses. But that will have to wait..
The unlisted Kiwi saw no traffic, the currently-public one sees attempts every hour despite the IP being dropped at the router.
Personally I'd just drop it at the router unless you want to help the user who may be well intentioned, but could also be unintentionally D.O.S.ing online receivers.
I might allow it again later (after work) and do some network sniffing.
Jul 30 09:05:45 kiwisdr kiwid: 06:06:25.345 01.. 1 15598.00 kHz usb z8 "47.88.219.24" Singapore (ARRIVED)
Jul 30 09:05:58 kiwisdr kiwid: 06:06:37.838 01.. 0 W/F BAD PARAMS: sl=18 50|48|49 [2019/7/30 17:05:50] ip=47.88.219.24 ####################################
Jul 30 09:05:58 kiwisdr kiwid: 06:06:37.918 01.. 0 SND BAD PARAMS: sl=18 50|48|49 [2019/7/30 17:05:50] ip=47.88.219.24 ####################################
Jul 30 09:06:57 kiwisdr kiwid: 06:07:37.725 01.. 0 W/F BAD PARAMS: sl=18 50|48|49 [2019/7/30 17:06:50] ip=47.88.219.24 ####################################
Jul 30 09:06:58 kiwisdr kiwid: 06:07:37.796 01.. 0 SND BAD PARAMS: sl=18 50|48|49 [2019/7/30 17:06:50] ip=47.88.219.24 ####################################
Jul 30 09:07:58 kiwisdr kiwid: 06:08:37.785 01.. 0 SND BAD PARAMS: sl=18 50|48|49 [2019/7/30 17:07:50] ip=47.88.219.24 ####################################
Jul 30 09:07:58 kiwisdr kiwid: 06:08:37.866 01.. 0 W/F BAD PARAMS: sl=18 50|48|49 [2019/7/30 17:07:50] ip=47.88.219.24 ####################################
Jul 30 09:08:58 kiwisdr kiwid: 06:09:37.757 01.. 0 SND BAD PARAMS: sl=18 50|48|49 [2019/7/30 17:08:50] ip=47.88.219.24 ####################################
Jul 30 09:08:58 kiwisdr kiwid: 06:09:37.873 01.. 0 W/F BAD PARAMS: sl=18 50|48|49 [2019/7/30 17:08:50] ip=47.88.219.24 ####################################
Jul 30 09:09:58 kiwisdr kiwid: 06:10:37.749 01.. 0 SND BAD PARAMS: sl=18 50|48|49 [2019/7/30 17:09:50] ip=47.88.219.24 ####################################
Jul 30 09:09:58 kiwisdr kiwid: 06:10:37.837 01.. 0 W/F BAD PARAMS: sl=18 50|48|49 [2019/7/30 17:09:50] ip=47.88.219.24 ####################################
Jul 30 09:10:57 kiwisdr kiwid: 06:11:37.720 01.. 0 SND BAD PARAMS: sl=18 50|48|49 [2019/7/30 17:10:50] ip=47.88.219.24 ####################################
Jul 30 09:10:58 kiwisdr kiwid: 06:11:37.825 01.. 0 W/F BAD PARAMS: sl=18 50|48|49 [2019/7/30 17:10:50] ip=47.88.219.24 ####################################
Jul 30 09:11:06 kiwisdr kiwid: 06:11:46.177 0... 1 5598.00 kHz usb z9 "47.88.219.24" Singapore (LEAVING after 0:05:34)
iptables -I FORWARD -s 47.88.219.24/24 -j DROP
My "Drop at the router" sees them test access every 78 minutes so not exactly heavy traffic.
In any even, other than having to make sure the iptables entry doesn't get washed out by FW changes it seems a useful solution.
My guess is that China is mass producing Kiwi clones for RF monitoring behind their firewall and someone has been tasked with writing the info-scraping software.
I am not sure if this is related, but the radio related website https://www.hfunderground.com/board/ which I run was getting overrun with bots a few days ago. You get three chances to guess from where, and the first two don't count. Hundreds at a time, at one point I saw over 500. They have stopped, for now anyway, but I am seriously looking into figuring out how to geoblock China if it happens again. It's an ugly solution which I don't want to have to implement, but it's potentially an even uglier problem.
This is why we can't have nice things.
I wish I could find a good argument against what you suggest...
should block it out. I'll watch and see if it does. A whois search lists Alibaba as the owner and has information on complaining about abuse.
iptables -I INPUT -s 47.88.219.24/24 -j DROP
iptables -I INPUT -s 184.22.160.13/24 -j DROP
since I'm trying to stop packets from two different offenders at the kiwi rather than from being forwarded by the router. This I followed with:
iptables-save
so that it will (I hope) get restored upon reboot. Examining the results I get:
root@kiwisdr:~# iptables -L
Chain INPUT (policy ACCEPT)
target prot opt source destination
DROP all -- 184-22-160-0.24.nat.tls1a-cgn02.myaisfibre.com/24 anywhere
DROP all -- 47.88.219.0/24 anywhere
Chain FORWARD (policy ACCEPT)
Chain OUTPUT (policy ACCEPT)
I'm not familiar enough with iptables yet to know if this will be sufficient, perhaps only the INPUT rule is needed. Maybe someone who knows can suggest whether this is correct or whether there's a better way.
Maybe the KiWi needs additional mechanisms to automatically defend against such incursions, or at least flag them up ?
Maybe it would be a good idea for all KiWi's to have the IP address blocked, at least until it's better understood what's going on, by which time it may be too late.
Personally I don't want to be assimilated into a Chinese Botnet :-(
Thanks, Claire
The steps I gave before seem to have fixed the problem for me. I am not an expert in this area either but no one has yet commented that there is a better way. To accomplish the block I first logged into my kiwi as root. I did this using secure shell, ssh, on a Linux host but this is also possible from a Windows machine via PuTTy or similar. Using PuTTy, simply enter the address, port 22, and it should then ask you to OK the connection. After you do, it will ask you who you want to log in as. Answer 'root'. That should get you a command line prompt from the kiwi. Once logged in I executed three lines:
iptables-save
There may be even easier ways but that's all I did and it seems to have worked, the log is no longer reporting these hits. Presumably these could start again from a different IP address and I would need to repeat one of the above first two commands with that address in place of the one shown.
I do appreciate your time writing down these steps...it helps me and likely other Kiwi users as well that want the apply this temporary fix.
Thanks again, Claire.
I was able to enter these commands directly via the KiWi admin console page.
I don't know if this is possible, but the responses I got back seem to indicate that it worked OK.
iptables -N LOG_DROP
iptables -A LOG_DROP -j LOG --log-prefix "INPUT:DROP: " --log-level 6
iptables -A LOG_DROP -j DROP
iptables -I INPUT -s 47.88.219.0/24 -j LOG_DROP
then make those rules persistent:
sudo apt install iptables-persistent
OR if this package was already installed:
iptables-save > /etc/iptables/rules.v4
You can check on the attempts by:
dmesg | grep INPUT:DROP | tail -10
and adjust the number at the end for the number of line items you'd like listed; 10 fits within the admin console window.
If some activity managed to crash the Beagle it is easier to review the event if it is recorded elsewhere.
As said previously, where the device allows, block at the router rather than the Kiwi, assuming an address is in any way malicious, it is better to protect the network than just one device.
For those who don't want to buy a new router consider using an older pc/laptop (minimum two networks) with PFsense or some other opensource solution, if only for a short while.
Thanks for the good ideas. I tend to do everything from a remote command line so didn't even consider the Kiwi console which is, of course, most accessible. By remoting in I get the advantage of history and easy copy/paste - which I tend to need a lot when I'm fussing around trying to understand something new. But I agree that simply entering W1EUJ's suggestions from the console works just fine and has the excellent benefit of generating a log.
Hopefully Claire and others followed this.
However it only works if you have local access to the KiWi, otherwise you will need to ssh in.
To wit:
Sat Aug 3 06:44:48 01:23:14.672 0... 0 W/F BAD PARAMS: sl=17 50|48|49 [2019/8/3 14:43:54] ip=47.88.219.24 ####################################
Sat Aug 3 06:44:48 01:23:14.772 0... 0 SND BAD PARAMS: sl=17 50|48|49 [2019/8/3 14:43:54] ip=47.88.219.24 ####################################
Sat Aug 3 06:45:49 01:24:15.065 0... 0 SND BAD PARAMS: sl=17 50|48|49 [2019/8/3 14:44:55] ip=47.88.219.24 ####################################
Sat Aug 3 06:45:49 01:24:15.070 0... 0 W/F BAD PARAMS: sl=17 50|48|49 [2019/8/3 14:44:54] ip=47.88.219.24 ####################################
Using "whatismyipaddress.com" I tracked it to Singapore, and the ip address indicated it was owned by Alibaba Tech (USA). I have only seen this one IP on my log. I'll use my router to block it here. Truly a pain-in-the-a**.
Brendan WA7HL
I used ping and traceroute to find the path from the UK and from a machine in Singapore, from UK 200ms and from Singapore 3ms BUT both packet routes showed a common IP addresses in China (Alibaba maybe).
It might be that the thing is in Singapore but local (Singapore) traffic has to go through the "great firewall".
Also using the geographic block list setup at https://mikrotikconfig.com/firewall/ and selecting China+Singapore does not include that range, maybe that tool is out of date.
