How make the audio smoother on a slow connection of 64 kbps ?
Thank you for the many receivers around the world at the website.
I am using an Android 7 Phone to tune in via my free internet of 64 kbps.
I can reach the radio sites and tune in without any problem. However the audio streaming is not smooth. It stop at 1/4 of a second and resume repeatedly.
May I know if under the Tuner Menu, Is there any setting that I can adjust to make the streaming smoother?
For sites tat have water fall, Is there anyway for me to turn it off once I get my favourite station?
Thank you
Thank you
E.G where the sdr is http://stucapon.plus.com:8073
The no waterfall version (with last frequency or default) is http://stucapon.plus.com:8073/?&no_wf (note add the /? right before any instructions)
The no waterfall, set to 882kHz, AM Mode would be http://stucapon.plus.com:8073/?f=882.00am&no_wf
If you start on a waterfall SDR set the "WF Rate" to "off" *and make sure the Spectrum is off, then double check Compression is on as above
