How to decode FSK signals using FSK Extension/Decoder - Not found on Forum search
                    Once the tone-bars are set on a FSK signals commonly found on 20-meters and going thru all the possible ITAC/ASCII/CIRC476 and 5Nv1--->end-of-selections
plus all BAUD selections, nothing ever decodes.
How is this done by others ? Please reply on this forum AND to dick.bingham@gmail.com in case I miss it on this forum
73 Dick/w7wkr
73 Dick/w7wkr
I don't know that much about ham use but I believe the old-time RTTY stuff is more likely to be 5N1 or 5N1.5 and ITA2 as the encoding. With some skill you can use the "scope" and "framing" functions from the mode menu, instead of "decode", to help narrow down the correct baud and framing values (just like the "baud error" indicator helps select the correct baud rate). Although these functions are not currently documented.
[A bit later] Sure enough, I was able to tune some contest RTTY on 40m using a Kiwi in The Netherlands. As seen in the screenshot below I used shift=170, baud=45.45, framing=5N1.5, encoding=ITA2, not inverted. I found I couldn't get away with any other framing as you can sometimes do with real modem hardware, i.e. 5N1 and 5N2 didn't work. UZ2I calling CQ test:
https://forum.kiwisdr.com/uploads/Uploader/67/c5f074870abb26664ba10a3da91372.png
