Can not access kiwi using kiwisdr.local:8073 [fixed with avahi-daemon restart]
I have always been able to access my kiwi using the kiwisdr.local:8073 address, on my iOS or OS X devices (never using windows though, always had to use the IP address for that).
A few days ago, I could no longer access it via the kiwisdr.local:8073 on my iOS devices either. Have run all software updates and done a rebuild of the kiwi as well, and the result is the same.
Have checked its hostname is set to : kiwisdr
Anything I am missing here?
Id like to get it back to how it was if possible, can still access locally via IP address no worries though.
Cheers
Simon
Cheers
Simon
"I had the same issue and found out how to fix it: turn any of the sharing services ON in the system preferences.
(File sharing worked for me)."
(https://discussions.apple.com/thread/7707202)
I am sure it is sometching on the kiwi which has changed, because I have a MacBook which I hadnt used since I initially configured the kiwi with it, so hasnt had any config changes or software updates since then, when it was working.
Type "scs avahi-daemon". Do you see messages like this that give the impression avahi is running?
(in all the following messages "www" will likely be replaced with "kiwisdr", the default Linux hostname of the Kiwi. My Kiwi happens to be named "www") If not, try restarting with "scst avahi-daemon", "scsa avahi-daemon" and another "scs avahi-daemon" and see if you get something like this: If that doesn't work type "which avahi-daemon". Does it answer "/usr/sbin/avahi-daemon" ?
Many thanks for your reply - I really appreciate it.
Best regards,
Simon
I would assume that rebooting it should have fixed the issue previously, but didnt..anyhow all good now.
