Setting Dispalyed Bandwidth
                    I need to set the waterfall display bandwidth as follows.  15 to 30 MHz
Thanks
Larry
                            Thanks
Larry
When you use the "--wf" option with kiwiclient (i.e. as used by the "wf:" target in the Makefile) what happens is the Kiwi sends waterfall data at zoom level zero (0 - 30 MHz) at a 1 Hz update rate by default. The data is 1024 bins wide which is the size of the waterfall FFT and also how many bins are seen on the browser interface. So at zoom=0 each bin represents roughly 30 kHz of spectrum (30 MHz / 1024 bins ~= 30 kHz).
I recall you said your analysis application wanted 512 bins of input data. So one thing you could do is simply throw away the first 512 bytes of output data on each update. Then you'd be left with 512 bins of data for 15 - 30 MHz. Now there is a --zoom option in kiwiclient as well but it turns out it isn't implemented quite correctly at the moment. It would be easy to fix however and then together with the -f option to set the center frequency you could set whatever power-of-two zoom sub-multiple of 30 MHz you wanted. For example as Ron said set the frequency to 22.5 MHz (the middle of the 15-30 MHz segment) and zoom=1. Then you'd get 1024 bins beginning at 15 MHz each with about 15 kHz of resolution.
