Power issues.
                    After a power cut power does not restore to the Kiwi's.
However, if I have the PSU powered up , unplug the Kiwi's and plug them back in again they power up no problem but not while the PSU is attached.
It's a linear supply.
Any ideas ?
Any ideas ?
But when you plug the power supply into the Kiwi the cap is already charged and the waveform appears to ramp up quickly.
Would it be possible a clean UPS exists ? this would be even better if it were cheap enough although I could probably live with it if it were not so clean for some hrs of backup.
The Kiwi takes very little power but light wiring or poor connectors could exacerbate any momentary current issues.
Imagine this the PSU may be just capable of getting the 5V up in the time the Beaglebone requires, but the wiring/connectors drop just enough in resistance to delay the full voltage. It's a long shot but worth experimenting with before looking for other supplies.
The issue is also not specifically the supply being not clean it's just the time taken for the voltage at the Beaglebone (through wiring and Kiwi DC filtering) to get where it needs to. From other posts and personal experience increasing the voltage by about 0.3V can sometimes help. The ideal solution would be have some way to remotely switch the DC side once the PSU is powered.
There are quite a few IOT switches, networked relay boards or add ons for say Raspberry PI.
