Audio queue depth slowly drops to zero, then resets, causing audio underrun - 8 receiver mode
                    I've been using some of the receiver capacity to run WSPR decoders while allowing public access for general listening, but this intermittent audio problem is very noticeable when it happens. It does not seem to happen in 4-receiver mode where the queue depth stays reliably at 4 or 5. It happens more often when WSPR has a lot of decoding to do.
I've only seen it happening in 8-receiver mode with several WSPR decoders on active bands configured at startup. Over a variable period of a few minutes, the audio queue depth drops from 5 to zero and then resets to 5. There are slight 'skips' in the audio as the queue depth drops and then a short gap when it resets from 0 to 5. The underrun indicator flashes and the counter increments.
I'm using Chrome on Windows 10. KiwiSDR 1.261, unit 3663. I had a look through the bug list and didn't see anything that seemed to fit this description. Any suggestions you have that could alleviate the problem are greatly appreciated.
This behavior is a bug, but also difficult to fix. So it probably won't be anytime soon given everything else that is being worked on.
