Possible TDoA problem when using KiWi's in 3 CH mode [fixed in v1.255]
                    This afternoon I tried using my second KiWi (in 3ch mode) running v1.250 to perform some TDoA runs.
The initial sampling completed OK, but when it tried to process the captures, after a while it came back with an "out of memory: use fewer Kiwis or check signal quality" error message.
Selecting the same TDoA but using my public KiWi running v1.249 in 4ch mode ran OK.
Changing my second KiWi running v1.250 back to 4ch mode and the TDoA ran OK.
Changing my second KiWi running v1.250 back to 3ch mode and I get the same error message.
I have previously used the KiWi in 8ch mode for TDoA and this ran OK, so I assume it's just a problem with the 3ch Mode.
From the CHANGE_LOG file:
Also some further UI improvements:
