kiwid only listening on IPv6
kiwid is only creating a listener for IPv6. I've tried disabling IPv6 via sysctl and rebooting, but it's still not starting an IPv4 listener. Is there a config parameter I can manually change to get it to listen on 0.0.0.0 (all IPv4 interfaces) in addition to or instead of :: (all IPv6 interfaces)?
I'm running v1.245.
Active Internet connections (only servers)
Proto Recv-Q Send-Q Local Address           Foreign Address         State       PID/Program name
tcp        0      0 0.0.0.0:22              0.0.0.0:*               LISTEN      361/sshd
tcp6       0      0 :::8073                 :::*                    LISTEN      4785/kiwid
tcp6       0      0 :::22                   :::*                    LISTEN      361/sshd
Nov  7 22:02:13 kiwisdr kiwid: 00:00:00.286   KiwiSDR v1.245 --------------------------------------------------------------------
Nov  7 22:02:13 kiwisdr kiwid: 00:00:00.289   compiled: Nov  7 2018 21:57:21
Nov  7 22:02:13 kiwisdr kiwid: 00:00:00.292   -debian 8
Nov  7 22:02:13 kiwisdr kiwid: 00:00:00.292   /etc/debian_version 8.5
Nov  7 22:02:13 kiwisdr kiwid: 00:00:00.292   background mode: delaying start 30 secs...
Nov  7 22:02:43 kiwisdr kiwid: 00:00:30.374   reading configuration from file /root/kiwi.config/kiwi.json: 147 tokens
Nov  7 22:02:43 kiwisdr kiwid: 00:00:30.378   reading configuration from file /root/kiwi.config/admin.json: 81 tokens
Nov  7 22:02:44 kiwisdr kiwid: 00:00:30.766   serial number from EEPROM: [redacted my serial]
Nov  7 22:02:44 kiwisdr kiwid: 00:00:30.827   reading configuration from file /root/kiwi.config/dx.json: 7084 tokens
Nov  7 22:02:44 kiwisdr kiwid: 00:00:30.830   887 dx entries
Nov  7 22:02:44 kiwisdr kiwid: 00:00:30.844 ........          firmware: SDR_8RX_2WF
Nov  7 22:02:44 kiwisdr kiwid: 00:00:30.847 ........          firmware: rx_chans=8 wf_chans=2
Nov  7 22:02:44 kiwisdr kiwid: 00:00:30.849 ........          firmware: NRX bufs=8 samps=85 loop=85/85 rem=0/0
Nov  7 22:02:44 kiwisdr kiwid: 00:00:30.850 ........          firmware: NWF xfer=9 samps=911 rpt=50 loop=18 rem=11
Nov  7 22:02:44 kiwisdr kiwid: 00:00:30.850 ........          listening on default port 8073/8073 for "openwebrx"
Nov  7 22:02:44 kiwisdr kiwid: 00:00:30.854 ........          webserver for "openwebrx" on port [::]:8073
Nov  7 22:02:44 kiwisdr kiwid: 00:00:31.085 ........          ### using SPI_DEV
Nov  7 22:02:45 kiwisdr kiwid: 00:00:31.854 ........          FPGA version 1
Nov  7 22:02:45 kiwisdr kiwid: 00:00:32.314 ........          using DC_offsets: I 0.050000 Q 0.050000
Nov  7 22:02:49 kiwisdr kiwid: 00:00:36.094 ..2345..      5   14097.10 kHz usb z0  "WSPR-autorun" 127.0.0.1 (ARRIVED)
Nov  7 22:02:49 kiwisdr kiwid: 00:00:36.098 ..2345..     4    10140.20 kHz usb z0  "WSPR-autorun" 127.0.0.1 (ARRIVED)
Nov  7 22:02:49 kiwisdr kiwid: 00:00:36.101 ..2345..    3      7040.10 kHz usb z0  "WSPR-autorun" 127.0.0.1 (ARRIVED)
Nov  7 22:02:49 kiwisdr kiwid: 00:00:36.101 ..2345..   2       3594.10 kHz usb z0  "WSPR-autorun" 127.0.0.1 (ARRIVED)
Nov  7 22:02:49 kiwisdr kiwid: 00:00:36.110 ..2345..          UPDATE: check scheduled (startup)
Nov  7 22:02:49 kiwisdr kiwid: 00:00:36.255 ..2345..          UPDATE: checking for updates
Nov  7 22:02:50 kiwisdr kiwid: 00:00:36.830 ..2345..          DDNS: public ip [redacted public IP]
Nov  7 22:02:50 kiwisdr kiwid: 00:00:36.833 ..2345..          DDNS: lat/lon = ([redacted lat], [redacted lon])
Nov  7 22:02:50 kiwisdr kiwid: 00:00:36.836 ..2345..          DDNS: private IPv4 <192.168.242.199> 0xc0a8f2c7 /24 0xffffff00
Nov  7 22:02:50 kiwisdr kiwid: 00:00:37.302 ..2345..          UPDATE: version 1.245 is current
Nov  7 22:02:50 kiwisdr kiwid: 00:00:37.675 ..2345..          SERVER-POOL: 5 ip addresses for public.kiwisdr.com
Nov  7 22:02:50 kiwisdr kiwid: 00:00:37.679 ..2345..          SERVER-POOL: #1 89.17.134.135
Nov  7 22:02:50 kiwisdr kiwid: 00:00:37.682 ..2345..          SERVER-POOL: #2 81.236.135.130
Nov  7 22:02:51 kiwisdr kiwid: 00:00:37.682 ..2345..          SERVER-POOL: #3 142.104.83.74
Nov  7 22:02:51 kiwisdr kiwid: 00:00:37.682 ..2345..          SERVER-POOL: #4 103.26.16.225
Nov  7 22:02:51 kiwisdr kiwid: 00:00:37.682 ..2345..          SERVER-POOL: #5 64.136.200.36
Nov  7 22:02:51 kiwisdr kiwid: 00:00:37.682 ..2345..          auto NAT is set false
Nov  7 22:02:59 kiwisdr kiwid: 00:00:46.182 ..2345..          TIMEZONE: lat/lon from sdr.hu config: ([redacted lat], [redacted lon])
Nov  7 22:03:00 kiwisdr kiwid: 00:00:46.858 ..2345..          TIMEZONE: for ([redacted lat], [redacted lon]): utc_offset=-28800/-8.0 dst_offset=0/0.0
Nov  7 22:03:00 kiwisdr kiwid: 00:00:46.861 ..2345..          TIMEZONE: "PST", "America\/Los_Angeles"
