Suggestion and comments on GPS please [resolved, see list of improvements]
Would be interested to hear how people have achieved a good reliable GPS fix. I have tried and failed on a number of occasions, and so far tried the following.
Mag mount antenna (with 26dB LNA) mounted outside on metal plate.
Moving the antenna as far away from the house as coax will allow
Changing the antenna for another similar mag mount
Cutting off the thin coax and replacing it with thicker lower loss double screen coax.
I still can't get a reliable fix, sometimes its shows tracking 6,7,8 SATS and good 1,2 or 3
The position of the SDR makes it very hard to position the antenna with a clear view of the sky, it has around 40% clear view and other areas are obstructed by the house, trees, fence.
On occasions, it runs for while, 3.6K fixes but then stops.
I have checked the voltage on the SMA, thinking it could be an issue but its fine 3.3v
So how do others get on, what exactly do you need to do to get a reliable fix?
enclosed image shows a typical screen, tracking
It's a little disheartening with TDoA as I really wanted to be part of the system, and located close to London. Could my KIWI be faulty, of do you really have to have an antenna with 90% clear views of the sky?
Dave M0TAZ
https://forum.kiwisdr.com/uploads/Uploader/09/32600f840c5418dbcd90ef52b09ef0.jpg
Can you try a different antenna? We've had a few failures of the hockey puck mag-mounts that Seeed ships. Having only 40% view of the sky shouldn't be a problem. Especially not now that we have Galileo support.
In your image PRN29 having an RSSI of 528 is marginal. Those Galileo E1/8/9 trackings are false because the SNR was only 16 at acquisition. An RSSI in the 200s means the tracking loop is unlocked (and the "U" status symbol agrees).
Its probably not the best, but the antenna seems to pick up more after the change than before. In the end, I took the antenna out of the plastic box and terminated the braid onto the metal can behind the patch antenna. I read the document that's helpful, but how does one select an antenna that has "good out of band filtering" they all seem to come from China for £5.99 or less.
I did try another antenna that was factory original, but that didn't seem to help similar results.
The new section of coax is about the same size as RG58, but its much better, double screen, foil screen and solid centre core. I have around 3 or 4 meters, and it was terminated with an SMA from the manufacturer.
I dont have any issues with the QRP labs WSPR GPS, works just fine indoors and in the garden. I except the implementation of GPS in the KIWI needs a little more care than the QRP labs version and did hope the outside antenna would fix. I have ordered another 2 GPS antenna, one a chepo china special 26dB LNA and the other says "marine GPS with 25dB amp" to see if they help.
The image shows the best I have had for a while, what does the PLL "kick" signify?
Your new image above looks fine actually. RSSI in the 1200-1500s for Galileo is pretty normal. The GPS RSSIs are a little low. What concerns me is the shadow map. It's only been a 6 hour run, but it's clear you only see sats above 45 deg elevation. Worse, because you're at 51 deg latitude the GPS polar "hole" is coming into effect and that is limiting what you get above the W-E line. So your actual sky view is smaller than I thought.
But having only 212 fixes over a 6 hour period is terrible. Another issue is that when you limit your sky view to one area like this you have high "dilution of precision" (GDOP, https://en.wikipedia.org/wiki/Dilution_of_precision_(navigation)). This will cause the time/positions to be less precise and they may be so far off that they get filtered out.
I think from what you say my view of the sky is still too limited, I don't have a very good view of the horizon in any direction. Its worst to the North as the house is in the way, better South and West as you will see from the new shadow map.
6K fixes in 15 Hrs
I took the patch antenna out of its plastic housing and mounted it on a metal plate, earthing the shield of the coax to the metal plate. The metal plate is around 40cm x 40cm and it is
better, but still not reliable.
I feel the need to elevate the antenna somehow, to give it a better view of the horizon.
That's the next part of my resolution strategy :-)
1/ Remove GPS patch from the puck, replace coax with something double screened.
2/ Attached the braid and shield of the puck can to a metal plate 40 x 40 cm
3/ Elevated this in the air to provide some clearance for house/trees/fences/local clutter
Each time I did one of the above it got better, and I hope its now mostly fixed.
This is now coupled to a short length (circa 6m) of LMR400. That really is the best I can do now, short of re-locating the antenna on the roof. The GPS antenna was £15 delivered from China, and it would seem to be the real deal.
https://spectracom.com/products-services/gnss-simulation/gpsgnss-simulators?gclid=CjwKCAjw2MTbBRASEiwAdYIpseYAdL4X4Yesk-UGnJ_EYn9Hags3PRNiwBCbjQr8x5DRX_YVIZQ5WxoCTQEQAvD_BwE
