kiwid restarts after assertion failure in support/coroutines.cpp [fixed in v1.184]
                    Hello,
Just found quite a few records in /var/log/messages, suggesting that the kiwid restarts after assertion failure in support/coroutines.cpp:
Apr 22 18:39:30 kiwisdr rsyslogd-2007: action 'action 17' suspended, next retry is Sun Apr 22 18:41:00 2018 [try http://www.rsyslog.com/e/2007 ]
Apr 22 18:40:36 kiwisdr kiwid: 00:26:37.291 0123 3 7020.00 kHz lsb z2 "x.x.x.x" Saratov, Russia (ARRIVED)
Apr 22 18:42:43 kiwisdr kiwid: 00:28:44.766 012. 3 7045.23 kHz lsb z12 "x.x.x.x" Saratov, Russia (LEAVING after 0:02:18)
Apr 22 18:42:43 kiwisdr rsyslogd-2007: action 'action 17' suspended, next retry is Sun Apr 22 18:44:13 2018 [try http://www.rsyslog.com/e/2007 ]
Apr 22 18:43:23 kiwisdr kiwid: 00:29:24.747 0123 3 7020.00 kHz lsb z0 "x.x.x.x" Businovo, Russia (ARRIVED)
Apr 22 18:51:20 kiwisdr kiwid: 00:37:20.887 0123 TaskSleepID: pending_sleep =========================================
Apr 22 18:51:20 kiwisdr rsyslogd-2007: action 'action 17' suspended, next retry is Sun Apr 22 18:52:50 2018 [try http://www.rsyslog.com/e/2007 ]
Apr 22 18:51:20 kiwisdr kiwid: 00:37:20.903 0123 assertion failed: "ct->sleeping == FALSE" support/coroutines.cpp line 1574
Apr 22 18:51:31 kiwisdr kernel: [164727.096403] bone_capemgr bone_capemgr: part_number 'BB-SPI0-01', version 'N/A'
Apr 22 18:51:31 kiwisdr kernel: [164727.096435] bone_capemgr bone_capemgr: slot #20: override
Apr 22 18:51:31 kiwisdr kernel: [164727.096452] bone_capemgr bone_capemgr: Using override eeprom data at slot 20
Apr 22 18:51:31 kiwisdr kernel: [164727.096467] bone_capemgr bone_capemgr: slot #20: 'Override Board Name,00A0,Override Manuf,BB-SPI0-01'
Apr 22 18:51:31 kiwisdr kernel: [164727.097242] device-tree: Duplicate name in spi@48030000, renamed to "spidev@0#13"
Apr 22 18:51:31 kiwisdr kernel: [164727.134509] bone_capemgr bone_capemgr: slot #20: dtbo 'BB-SPI0-01-00A0.dtbo' loaded; overlay id #16
Apr 22 18:51:31 kiwisdr kiwid: 00:00:00.569 .... KiwiSDR v1.179 --------------------------------------------------------------------
Apr 22 18:51:31 kiwisdr kiwid: 00:00:00.573 .... compiled: Apr 19 2018 15:23:17
Apr 22 18:51:31 kiwisdr kiwid: 00:00:00.577 .... -debian 8
Apr 22 18:51:31 kiwisdr kiwid: 00:00:00.577 .... /etc/debian_version 8.7
Apr 22 18:51:31 kiwisdr kiwid: 00:00:00.577 .... background mode: delaying start 30 secs...
Apr 22 18:52:01 kiwisdr kiwid: 00:00:30.610 .... reading configuration from file /root/kiwi.config/kiwi.json: 139 tokens
Apr 22 18:52:01 kiwisdr kiwid: 00:00:30.615 .... reading configuration from file /root/kiwi.config/admin.json: 73 tokens
Apr 22 18:52:02 kiwisdr kiwid: 00:00:31.003 .... serial number from EEPROM: 1247
Apr 22 18:52:02 kiwisdr kiwid: 00:00:31.124 .... reading configuration from file /root/kiwi.config/dx.json: 6956 tokens
Apr 22 18:52:02 kiwisdr kiwid: 00:00:31.127 .... 883 dx entries
Apr 22 18:52:02 kiwisdr kiwid: 00:00:31.140 .... listening on default port 8073/8073 for "openwebrx"
Apr 22 18:52:02 kiwisdr kiwid: 00:00:31.144 .... webserver for "openwebrx" on port [::]:8073
Apr 22 18:52:02 kiwisdr kiwid: 00:00:31.378 .... ### using SPI_DEV
Apr 22 18:52:03 kiwisdr kiwid: 00:00:32.529 .... FPGA version 1
Looks like this is recurring issue:
root@kiwisdr:~# grep assertion\ failed /var/log/messages
Apr 22 06:35:36 kiwisdr kiwid: 00:24:16.124 0123 assertion failed: "ct->sleeping == FALSE" support/coroutines.cpp line 1574
Apr 22 09:49:01 kiwisdr kiwid: 03:13:14.778 012. assertion failed: "ct->sleeping == FALSE" support/coroutines.cpp line 1574
Apr 22 11:49:21 kiwisdr kiwid: 02:00:08.680 0.23 assertion failed: "ct->sleeping == FALSE" support/coroutines.cpp line 1574
Apr 22 13:27:19 kiwisdr kiwid: 01:37:46.848 012. assertion failed: "ct->sleeping == FALSE" support/coroutines.cpp line 1574
Apr 22 14:51:18 kiwisdr kiwid: 01:23:47.137 0123 assertion failed: "ct->sleeping == FALSE" support/coroutines.cpp line 1574
Apr 22 15:09:25 kiwisdr kiwid: 00:17:56.342 01.. assertion failed: "ct->sleeping == FALSE" support/coroutines.cpp line 1574
Apr 22 18:13:47 kiwisdr kiwid: 03:04:10.845 0123 assertion failed: "ct->sleeping == FALSE" support/coroutines.cpp line 1574
Apr 22 18:53:38 kiwisdr kiwid: 00:02:07.843 01.. assertion failed: "ct->sleeping == FALSE" support/coroutines.cpp line 1574
Anyone else got this, or is it just me?
Ivan,
UR5VIB
Ivan,
UR5VIB
Ivan,
UR5VIB
I replaced the failed GPS frontend IC (bought on Aliexpress, not sure about it's quality) a few months before, may be it's somehow related to this assertion ocurrence.
Ivan,
UR5VIB
Found another assertion failure in /var/log/messages:
Apr 24 09:33:20 kiwisdr kiwid: 06:38:06.599 0123 TaskSleepID: pending_sleep =========================================
Apr 24 09:35:22 kiwisdr kiwid: 06:40:08.656 0123 TaskSleepID: pending_sleep =========================================
Apr 24 09:38:08 kiwisdr kiwid: 06:42:54.699 0123 TaskSleepID: pending_sleep =========================================
Apr 24 09:58:13 kiwisdr kiwid: 07:02:59.194 0123 TaskSleepID: pending_sleep =========================================
Apr 24 09:58:47 kiwisdr kiwid: 07:03:33.403 0123 TaskSleepID: pending_sleep =========================================
Apr 24 10:00:01 kiwisdr kiwid: 07:04:47.478 0123 TaskSleepID: pending_sleep =========================================
Apr 24 11:18:34 kiwisdr kiwid: 08:23:20.670 0123 ca_pause -1594 0xfffff9c6 ca_shift=5588 code_creep=45110 code_period_ms=1 code_period_samples=16368
Apr 24 11:18:34 kiwisdr kiwid: 08:23:20.674 0123 assertion failed: "ca_pause <= 0xffff" gps/channel.cpp line 279
This one is less frequent:
root@kiwisdr:~# grep channel.cpp /var/log/messages
Apr 23 03:27:38 kiwisdr kiwid: 01:25:36.151 0... assertion failed: "ca_pause <= 0xffff" gps/channel.cpp line 276
Apr 24 00:40:49 kiwisdr kiwid: 03:27:48.405 .1.. assertion failed: "ca_pause <= 0xffff" gps/channel.cpp line 276
Ivan,
UR5VIB
