Use CAT6 shielded communications cable for antenna feedline, rotor control, and LNA power
                    I have a spool of shielded CAT6 cable and it would seem that it should make a reasonable antenna feed line to the KiwiSDR. Do the wire antenna input lugs work with a balanced feed line? If this type of cable is used and the power to the antenna LNA is on one pair, the RF from the antenna is on another pair, and a rotor control used the other two pairs, would there be a foreseeable problem?
https://forum.kiwisdr.com/uploads/Uploader/a2/ef23af060501a4e7369077d0f2a3ae.png
