Wideband pulsing noise & Noise Blanker absence: I'm in trouble! [NB added in v1.152]
                    Hi to all,
some days ago i received my brand new KiwiSDR KIT from a UK official reseller.
After manual assembling, cable setup and software update i put it on test with a magnetic loop antenna (Wellbrook ALA 1530+), head to head with other SDR radios (Elad FDM SW2, SDRplay RS2pro, etc) .
During day time it behaved in a good way, functionally wise is a very interesting device with a lot of potential.
I like a lot the possibility to use four WSPR decoders on four different bands placed without constrictions as well as the possibility to get a prompt snapshot of the whole shortwave spectrum.
But as soon as nightfall hit and street light turned on ... everything went south :-(
My receiving site, like many others, is subject to broadband pulsing noise coming from sodium street light during night time, that mostly affects lower shortwave bands.
Usually this is not a problem for my other SDR radios, programs like HDSDR, SDR#, FDM-SW2, fully defeat this noise cleaning the spectrum, the waterfall and the demodulated audio, with the integrated Noise Blanker functions.
KiwiSDR, right now, does not have NB or NR functions, so i got the tipical buzzing sound, that i was expecting knowing this temporay lack.
What i was not expecting is the fully scratched waterfall screen, the FFT function seems to overreact to this condition fullfilling with several thick & bright horizontal lines, making the function near to useless.
Other SDR programs, in the same conditiom, provide a much better plot even with the noise blanker turned off.
I attached some screens with comparison between KiwiSDR and Elad FDM S2 & HDSDR, operated with same antenna, through a magnetic RF power splitter; the HDSDR "RF NB" function was turned OFF and ON to show its action.
I got same results (but not showed in images) for RSP2 and RTL-SDR with HDSDR and SDR# (with "Baseband Noise Blanker" plugin).
So ... the question is ... there is the hope that a wide band Noise Blanker function, similar to HDSDR "NB RF" or SDR# "Baseband Noise Blanker" will be implemented for KiwiSDR in the near future ?
Is it possible, in the mean time, to modify the behaviour of the waterfall screen to avoid the thick bright lines ?
https://forum.kiwisdr.com/uploads/Uploader/27/81da9c9aaaeb8b7db6eaf470f6c934.jpg
https://forum.kiwisdr.com/uploads/Uploader/28/1dc9f2361595029859f7cb247bd7ed.jpg
https://forum.kiwisdr.com/uploads/Uploader/1e/f3378ad60ec61dadc32599fcecd557.jpg
https://forum.kiwisdr.com/uploads/Uploader/12/957db2a850e47b81a93c7823e0abb5.jpg
https://forum.kiwisdr.com/uploads/Uploader/d0/63e15208fc22ddc0fbc853250436cd.jpg
https://forum.kiwisdr.com/uploads/Uploader/47/02f18ce6e82ee858b650ddde187a90.jpg
https://forum.kiwisdr.com/uploads/Uploader/99/564bf2a320683ab4eefa9824dd2cac.jpg
https://forum.kiwisdr.com/uploads/Uploader/7a/eb65ab127c2b45876ba5bfcdc10128.jpg
How many simultaneous connections were there to the Kiwi when these screenshots were taken? Just one?
Does the red "OV" indicator ever appear at the top right of the S-meter? Currently, if the ADC overloads for even a single sample OV will appear.
Are you able to add some attenuation at the Kiwi input? Say 10 - 30 dB? I'm wondering if the +20 dB ADC preamp is reacting badly to these pulses.
If you add 10 dB of attenuation, but the horizontal noise lines drop more than 10 dB, this indicates a possible problem.
When you tune to a quiet frequency do the pulses on the Kiwi sound substantially worse than the other devices/programs with their NB off? On the Kiwi the audio and waterfall paths have less hardware & software in common than other SDRs and SDR software.
"How many simultaneous connections were there to the Kiwi when these screenshots were taken? Just one?"
- yes, just only one.
"Does the red "OV" indicator ever
appear at the top right of the S-meter?"
- OV indicator never light up among those tests, the power splitter insertion loss seems enough for most day condition.
"I'm wondering if the +20 dB ADC preamp is reacting badly to these pulses."
- i was wondering about it too, i tried to put inline a 10 dB attenuator with no success, of course i can try greater values.
"If you add 10 dB of attenuation, but the horizontal noise lines drop more than 10 dB, this indicates a possible problem."
- i will check this.
"When you tune to a quiet frequency
devices/programs with their NB off?"
- sound wise, with NB off, Kiwi & other SDRs are pretty similar in most conditions, the real difference is in waterfall image; of course turning on NB function gives you a perfect audio, spectrum and waterfall screen.
"Also, why with HDSDR does the top bit of the waterfall have a
slightly different colormap or setting? I'm just curious why it looks
different to the rest."
- not sure to exactly undertand this question (my bad, of course), i will try to explain how i set waterfall in HDSDR hoping to cover your point.
Usually i select the "Spectran" color palette (it's based on black-blue-white color curve), then i increase both waterfall brightness & contrast settings to obtain a crisp and clear spectrum representation; palettes with more colors are pretty but tend to hide fine gradients and to be messy in noisy condition.
For my personal taste "Spectran" is the right compromise.
One thing that makes the HDSDR waterfall screen pretty and easy to watch is its autoscale function : if the noise floor changes but the overall dynamic range is maintained, you do not see any chromatic variation, while other programs require continuous offset settings change (this is especially true for SDR#) to avoid black crushing or color top saturation. This feature, in addition to high frequency resolution and very fine/linear brightness rendering, makes it my first choice for small signal hunting. Also the fact that spectrum plot has separate settings from waterfall helps a lot.
going to need root ssh access to the Beagle of a Kiwi that has this
issue for development and testing. You'd just have to open port 22 on
your router and point it at the Kiwi. Set a password on the root and
"debian" accounts and let me know what the root password is (email
support@kiwisdr.com)"
Here the issue is currently present from about 17.30 to 07.30 (UTC + 1 hour time).
I will do required settings and i will provide you access information by email.
Thanks for your attention.
i was going to bed but i saw your forum's post update on my phone, so i promptly updated my KiwiSDR for a fast try ... BINGO !
It's working !
Around 5Mhz, one of the the frequency band most affected by the problem, is obtaining decent results.
Right now (03.30 AM) it's not the worst noise condition of the day, the peak is around 18.00 - 24.00 (local time), so tomorrow i will do several other test at different time and frequency band.
If you look to the attached image, the upper portion of the waterfall is "cured" with NB function turned ON, while bottom was taken with NB turned OFF.
Demodulated audio quality changes in consequence.
As a first try, it's a very good result, THANKS a LOT.
In the mean time, i prepared my Kiwi SDR for full WEB access, email with IP addr & login data is on the way.
See you tomorrow.
https://forum.kiwisdr.com/uploads/Uploader/3d/e90eb4294935464b4b33e1f7ac10d8.jpg
i just sent to you (support@kiwisdr.com) the email with my KiwiSDR web access data.
if you can, give a try to my receiver (see the email that i sent to you for address), it's online with one of the worst noise condition ever seen, NB struggle to work.
Just out of curiosity, in your screenshot is visible a "Pref" button aside the "WF rate" slide, not present in my 1.153 version.
Is it a special developer menu ?
https://forum.kiwisdr.com/uploads/Uploader/ab/66d7a4739ccb6a5e2c3dabd8f5d3d8.png
In my personal case, values beyond 1000us, while cleaning better waterfall, start to be disruptive against decoded audio.
It would be interesting to test lower values than 100us, maybe this is the lower limit imposed by the implementation.
About multiple states NB toggle function, i would instead prefer some direct selection user memories like "NB1" - "NB2" - "NBx", but i understand that adding new items to the control panel requires a change in its size, shape and structure.
I have to thank John for the prompt response to my situation, that saved me from the need to put on sale this SDR.
