Dealing with excessive noise - SOLVED: Ethernet over Power caused noise
I've set up a KiwiSDR however the system seems to be showing an excessive amount of noise
https://forum.kiwisdr.com/uploads/Uploader/b8/0263ea226d3d1384e7edbadcdc7f4b.jpg
The set up is this:
Antenna is Welbrook loop ALA1530LNP
Power supply is a 5v and 12v Linear power supply (All in one unit) specifically this one)
It can be accessed at http://110.22.1.17:8073/ (I have not bothered to put it on sdr.hu just yet)
Since the local AM stations were so strong I put on the RTL-SDR AM filter on the input, which appears to have worked but there is still noise (across the full range)
I did try to move the SDR outside and run everything from a battery (12v with this converting to 5v) but the noise still exists. I also tried a non active antenna (The one provided with the RTL-SDR) and while the single is weaker, there is still a lot of noise.
At this point I'm not really sure what I can do to remove the noise, could the unit be faulty?
Any suggestions at this point would be very welcome
I have attached an image of the setup
https://forum.kiwisdr.com/uploads/Uploader/b8/196e1242399f83da273946a6c1d45e.jpg
https://forum.kiwisdr.com/uploads/Uploader/5d/fc71ce2307075974fdb9ab435e8823.jpg
https://forum.kiwisdr.com/uploads/Uploader/b5/14f5bdf550a4aa8d901dbc67ea894a.jpg
https://forum.kiwisdr.com/uploads/Uploader/3f/a59ee1ed39baf178167b135ac8c0e0.jpg
have got damp with condensation at night then this becomes conductive from the
screen to the inner and thus causes a noise voltage. Or sometimes you can get a
conductive crud across the BNC if its a solder type. Its a good idea to use the PVC boot packed with Vaseline or DC4
grease to keep out the damp.
The following suggestions are made from Andrew Ikin, the creator of the Wellbrook antenna:
The problem could be a poor amp. connection to the loop. Or the
head amp. has failed or the Interface may have a fault.an you try the loop with another 12V power supply first. If the
noise is still there then tighten the head amp. connection on the loop.
If the fault is still there then test the Interface:
Ensure that there is 11Volts being fed to
the loop. Also make sure that the feeder cable is okay; no shorts or open
circuits. If the above is okay then test the Antenna Interface.
Connect a wire antenna to the Receiver and
measure the gain on a local MW station. Then connect the Interface to the
receiver and then connect the wire antenna to the Interface BNC via a 0.1uf
cap. The gain should be 9dB higher.
If
the Interface is okay; it amplifiers and provides 11V to the loop, then
suspect the loop amplifier is faulty."
Also, Ive moved the antenna and SDR to parts of the house which are not heavily using electronics but the ADC is still showing a lot of overload. The AM band is clear, but at this point Im not really sure what to do, perhaps I should reach out to Andrew and see if he has any ideas regarding the wellbrook. Any other thoughts?
The attached images
Also the SDR is live at the above mentioned address if anyone want to get a closer look at the noise
https://forum.kiwisdr.com/uploads/Uploader/9b/ba5636f0f1000e565944d6800b9272.jpg
