There will be proxy service downtime/restarts as the crashing problem is debugged.
v1.115: reduced audio latency, especially for local connections
In this release you should notice reduced audio latency, i.e. the delay between changing something like the frequency or mode and the resulting change in audio. This is especially true for local connections. A connection where the Kiwi and computer running the browser are on the same local subnet. The audio buffering is reduced even more for this case.
To switch back to the previous behavior click on the "Snd" button (above the "More" button) so it shows white instead of green and then reload the page. This setting is saved in a cookie across reloads like some of the other buttons are.
The lower latency allows it to be used with a co-located transmitter in a live QSO. A fun echo effect can be created, the shorter delay/latency is similar to the time taken by a radio signal to go around the earth!
73, Rob
M0RZF
Could this buffer be still reduced ?
..... for the series: we are never happy of what we have ...
Phil
In the vx117 I am noting that the time taken to change from a cw station to another in the local lan has rised a little compared to the x116.
It seemed to me that the 116 was faster in change from 117... or no ?
Phil
