Minor problem with frequency jump [fixed in v1.823]
Hi and good morning from Germany,
I have discovered a minor problem (on my end).
When I select the 40 m amateur radio band and go to 7200 kHz and then click the “-” button (-1 kHz), a jump of -5 kHz is executed. So from 7200 to 7195 kHz.
However, it should probably be -1 kHz, since this is the 40 m amateur radio band. After that, it continues correctly with -1 kHz.
When I select 7199 kHz, the jump is also performed correctly with -1 kHz.
In the other direction, +5 kHz is OK because that is where the 41 m broadcast band is located.
I also tested the 80 m and 20 m bands. At the upper limit of the 80 m band (3800 kHz) and also at the upper limit of the 20 m band (14350 kHz), this does not happen; the jump is correct at -1 kHz.
Regards, Steffen
  • You can define the channel values ​​for each band, whether amateur or broadcast, in the DX/Band bars tab in the Chan section, enter 1. Next to the band you want to edit, the + and - buttons will change the freq. every 1 kHz, so for AM stations it will be 1 kHz, not 9 or 10 depending on the defined region.
  • I know the settings. They are correct as far as I can tell.
    The jump from 1 kHz in the 40 m amateur radio band does work.
    However, only the special case of 7200 kHz back to 7199 kHz results in a jump from -5 kHz to 7195 kHz.
    From 7199 kHz, it jumps correctly to 7198 kHz. It also works correctly for all other amateur radio bands.
    Regards, Steffen
    edited October 6
    Okay, I think I have this fixed. Will be in the next release.
    It a corner case: When two bands abut each other, and you're tuned to the exact frequency in common with the bands (e.g. 7200 as mentioned here), the - - - buttons should use the lower band's tuning step. And the + + + buttons should use the upper band's tuning step.
    The story is slightly more complicated for overlapping bands. Which right now occurs for ITU R3 (Asia/Pacific) with the 40m amateur and 41m broadcast bands. Basically 41m has priority because it's first in the admin DX tab "band bars" list (unless you've changed it).
    jimjackii
  • Hi John,
    Thanks.
    Unfortunately, I hadn't noticed the overlapping areas. Then of course it makes sense to use the prioritized area as a basis.
    Regards, Steffen
