W3006 antenna module
Hi folks,
I’m working on integrating an SDR setup (specifically KiwiSDR) in a location with RF interference issues, and I stumbled across an antenna module called W3006.
Before I proceed, I wanted to see if anyone here has used or tested the W3006 (or similar antenna modules) with KiwiSDR, or in environments with strong interference. I’d appreciate your insights on its performance and potential challenges. I plan to use the W3006 as the frontend antenna for KiwiSDR, especially in a location where space is limited and interference is high. Key goals are good sensitivity, noise immunity, and low distortion in crowded RF bands. I’m concerned about matching impedance, front-end saturation, external interference, and whether this antenna will degrade or improve reception.
So,,
In high-interference areas, how do you choose or modify antennas to mitigate overload and spurious responses? Do you prefer matching networks, filters (bandpass, low-pass), or attenuators in front of SDRs when using compact antennas? Any recommended alternative antennas or modules you’d suggest for crowded RF environments (especially for HF / VHF / general coverage use)?
I’d love to hear your feedback, tests, or anecdotes.
Thanks in advance for any help!
JM
    edited October 1
    Um, why would you put a 2.4+ GHz antenna in front of a Kiwi which has an upper frequency receiving limit of 30 MHz?
  • As @jks has pointed out, there is no point here.
    Perhaps you have misunderstood the Kiwi's frequency range?
    If you want to receive HF in a high QRM environment, you should look into magnetic loops - which in itself is a whole separate topic. Search the forums for which rabbit hole you wish to fall down.
    For other situations like RF overloads from nearby transmitters, there are a couple of devices on the Kiwi shopfront that can help.
    I feel you may want to expand on what you are trying to achieve here a little more.
