Using nRF24L01 Mini to Send Control Signals to KiwiSDR
Hi everyone,
I’ve got an idea I’m experimenting with: adding a small wireless controller to my KiwiSDR using the nRF24L01 Mini module to send control signals like filter adjustments or gain tweaks from another room. But I’m running into a few problems and wonder if anyone here has tried something similar or can help troubleshoot.
I've wired up the nRF24L01 to a small microcontroller (ESP32) that reads buttons/knobs and sends control messages over RF. On the KiwiSDR end, another ESP32 or microcontroller listens and issues local commands via the Kiwi’s REST API or GPIO pins. Tested everything close by, works reliably up to a few meters.
Issues I’m seeing:
There’s a noticeable lag (~200-500 ms) when I turn knobs; the Kiwi reacts slowly. As soon as I get further away or have walls, signal degradation causes missed packets. The nRF24 module seems sensitive; supply fluctuations or nearby electronics cause dropouts.
Are there tips to reduce latency (buffering, packet size, acknowledgment settings, RF channel selection)? For better range / reliability, would using a stronger RF board or external antenna help, or is interference in the Kiwi setup likely to dominate?
Happy to share sketches or wiring diagrams if helpful. Thanks in advance!
Jordan
Some thoughts:
