Local ip address
Hello
After having to restart my Kiwi due to router failure, I cannot find my ip address on the my.kiwisdr.com page. What could be the reason please ? It was ok previously.
Thanks
    edited September 2
    Are you connecting to my.kiwisdr.com from a device on the same local network as your Kiwi? If you were to, say, use your phone using the cell network (not WiFi) it would not work as the phone would be using the cell network's IP range, not the local network range.
    There is an entry on my.kiwisdr.com for your serial number for the local address range 192.168.1.xxx, last updated from the Kiwi booting on 29-Aug-25 09:55:43 UTC.
  • Yes, on my PC, which is on the same local network as my Kiwi. Before my router failed I was able to connect using 192.168.1 etc, but that isn't working now.
  • Okay, checking the logs I can see the change in public IP address. You can fix this by restarting your Kiwi so it updates my.kiwisdr.com with your current public IP.
  • Thanks a lot, I will give that a go, hopefully it will work.
  • That worked a treat thanks.
