Antenna switching using IO lines under Web GIU Kiwi SDR
Can it be possible to suppose say 4 of the IO lines to switch 3 antennas and termination from the RF and antenna select as standard config, im not too versed on the guts of code and linux to do a DIY can it be part of a Kiwi SDR GIU skin, use the IO lines on P9 connector
I hope you meant to say the P8 connector instead of P9. Don't use GPIO pins on P9. Some are already being used by the planned Kiwi upgrades.
I would discourage doing this in general. P8 pins not only go to the Beagle GPIO but also to the FPGA. If you make an error you will destroy the FPGA -- a very expensive mistake. Much easier and better to spend the money on an external antenna switch that is already supported by an existing antenna switch backend driver.
Thanks for the reply can you pleae give me example say using Arduino, USB, and relay drivers im guessing a Arduino nano has enough IO lines any examples of a circiit and sketch I assume the Beaglebone board will support USB com port
John already has some documentation on antenna switches.
I started making my own code to work with a 3rd party switch
https://github.com/smegoff/RAAS-4-Scripts
Also, check out this thread
https://forum.kiwisdr.com/index.php?p=/discussion/3249/what-antenna-switch
Can you point to a circuit using the USB port UART to switch antennas I'm guessing a Arduino sounds what I'm looking for
@FrankinAu , look at this topic
https://forum.kiwisdr.com/index.php?p=/discussion/3530/antenna-switch-kits-commercially-available
