v1.818
From the CHANGE_LOG file:
v1.818 August 9, 2025
Fixed problem where connections incorrectly originate from the local 127.0.0.1 loopback address.
When the local proxy service client (frpc) running on the Kiwi forwards packets to the
Kiwi server they will always have the IP source address 127.0.0.1. This occurs because frpc
and the server are running on the same computer. To not lose the actual IP address of the
person connecting frpc puts that IP in a special HTTP header. Well, for some reason, the
version of the Mongoose web server we use occasionally drops those special headers.
The root cause could not be found. But some time ago we ported a much more recent version
of Mongoose to the Kiwi and it doesn't have this problem. So the fix is to simply start
using this newer version.
Also, code was added to specifically reject forwarded connections with the special header
containing a local or loopback addresses. This might possibly affect private proxy setups,
like those using Tailscale or Nginx etc, if they incorrectly use a local or loopback in the
HTTP header. You can disable this specific change (but not the Mongoose upgrade) by going to
the admin "update" tab, bottom of the page, and setting "Disable recent changes?" to "Yes".
The SNR strong, wide-band signal filter has been withdrawn.
Works perfectly for me. Nicely done!
Thank you John, all cards up and running on v1.818 without any known probs.
Cheers
Paul
@bwilson Okay, that's good I guess. It's still a little concerning there was trouble earlier that wasn't fully understood.
The Mongoose bug/fix was very trivial, even though it had disastrous consequences. I was surprised that whatever HTTP transport engine Firefox uses allowed the error and Chrome-based browsers didn't (stricter protocol checking).
